B7200 Year / History?
   / B7200 Year / History? #1
PlanMan
Upstate NY
Kubota B7200
Could someone direct as to where I could find the history of my tractor? Year, in-service date, etc.?
Serial Number is B7200D60403
Thanks in advance.
   / B7200 Year / History? #2
Morning PlanMan.
Hope this helps...tractordata.com
Kubota
B7200
Manufactured: 1983 - 1990
Cost: (US Dollars) $ (1990)
Power:
Engine (HP): 17
PTO (HP): 14
Engine:
Manufacturer: Kubota
Fuel: diesel
Cylinders: 3
Displacement (ci): 56.6
Compression:
Rated RPMs:
Torque (ft-lbs):
Firing order:
Oil capacity (qts):
Transmission:
Forward: 6
Reverse: 2
Transmission:
Type: hydrostatic
Forward: infinite
Reverse: infinite
MFWD: opt
Capacity:
Fuel (Gal):
Cooling (Qt): 0
3-Point:
Category: I
Lift (lbs):
Power Take-off (PTO):
Type:
Rear speed (RPM): 540,825
Hydraulics:
Type: open
Capacity (gal): 4
Total Flow (gpm):
Outlet Flow (gpm):
Pressure (PSI):
Outlets: 1
Tires:
Ag front: 5.00-10
Ag rear: 8.00-16
Dimensions:
Weight (pounds): 1220
Wheelbase (inches):
Length (inches):
Width (inches):
Height (inches):
Ground clearance (inches):
Electrical:
Battery volts:
Ground:
Battery cold-cranking amps:
Alternator amps:
Serial Numbers:
1983 50532
1984 51758
1985 60683
1986 62548
1987 64737
1988 65307
1984 50026 (HST)
1985 50711 (HST)
1986 52531 (HST)
1987 55065 (HST)
1988 55977 (HST)
   / B7200 Year / History? #3
Thomas is giving you good info. TractorData.com is a great website for all brands of tractors and models. Looks like yours is a 1986 model. Ain't TBN great!!!! Enjoy your tractor. :)
Thanks Thomas & ovrszd. I did see that info. on the tractordata site, and yes it is a great site. But I still didn't know how to read the serial number regarding year, etc. For example, after the model (B7200D), does the next digit indicate the year? If so, it could be an '85-'88
overszd - How could you tell it is an '86?
Thanks again for your responses.
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
Adams Tender / Magnolia Trailer (A56438)
Adams Tender /...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
