B7610 Front Axle Leak
   / B7610 Front Axle Leak
I checked the oil level in the front axle yesterday and observed (and felt) what I consider excessive positive pressure when I removed the dipstick. I have checked the oil level in the front axle before, but never noticed (or recall) this much positive pressure built up inside the axle housing.
I couldn't help but wonder if this excessive pressure contributed to the "wetting" I have observed on the left front axle flange.
And lastly, has anyone else noticed this on their B7610? I would have thought there would be a vent to prevent this kind of pressure build-up.
Dave
   / B7610 Front Axle Leak #12
I have the 7510 and changed the front end to 80w-90 with recommendations from my dealer. The plug was hard to get out and I had to twist and pull as well, it certainly is not easy to get a grip on. I don't have any weeping yet but I will be keeping an eye on it now that I know. The heavy oil is much darker then the sudt easier to see on the dipstick. I wonder if you could add some food coloring to the sudt to make it stand out? Anyone try this?
   / B7610 Front Axle Leak #14
I had a ford , that would buildup alot of pressure specially when running on the road I would have 'wetting' and then leaking on the front seals.
I replaced the plug with a 1/2 in pvc water plug and drilled a couple of holes to vent in it.I dont understand why they are vented in any way formt he git go.
   / B7610 Front Axle Leak #15
I had the same problem with my 04 B7610.Dealer fixed one side,i brought it home ,two wks. later the other side started leaking.Ended up trading it in for a B26,not because i did'nt like the 7610,but just wanted something heavier.
The B26 has'nt leaked yet.....i'm keeping my fingers crossed.
When i had the 7610,i remember doing a search on TBN and found a piece about "venting" the front axle.Try doing a search under "venting front axle".There was a step by step thing with pictures and all.Worth a try.
Digger2
   / B7610 Front Axle Leak #17
I thought of that also, but isn't food coloring water based?
There are commericially made additives to color oils for visibility and identification .....This came up in a thread on checking hudraulic oil on the silly yellow dipstick..Hard to see....
But of course I didn't write down the information then.... :rolleyes:
STORAGE FEES (A51219)
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
2011 JOHN DEERE 329DT SKID STEER (A51242)
2011 JOHN DEERE...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
