B7800 Joystick flopping around
   / B7800 Joystick flopping around #1
Post Carbon
Pacific NorthWest
Kubota B7800, LA402 FEL
We're getting big snows here, and I'm using my baby to clear snow from the concrete driveway--third time today. Halfway through, my joystick stopped working on the up/down. It just flops around, up and down. The side-to-side is fine, and the curl of the bucket works no problem. But now I can't raise or lower my FEL at all, and I really need both functions to clear snow.
I've had some trouble with this before, and have removed the float detente entirely because I just couldn't make it work. I'm willing to take it all apart (even in the snow) but do you think it's a nut loose, or is the valve stuck? It doesn't feel like a stuck valve like I've had before--it's so loose and flopping.
Thanks for any ideas...
PC
   / B7800 Joystick flopping around #2
Loose and flopping surly suggests disconnected somewhere.
You might just get lucky and have lost a pin and lock.
Good luck!
   / B7800 Joystick flopping around #3
When you get the cover off you well see why.
Thanks, you were right. It wasn't a pin though, it was the entire joint rod end that had worked its way out. I had to take a few other things loose to get it back on easily. Tightened a few other things, then fired my baby up again and it's all working great. Driveway is now clear.
Is that normal for such a large bolt to work its way out like that? Don't remember ever reading about such a thing.
PC
   / B7800 Joystick flopping around #5
Is it possible that there was a jamb nut there?
Perhaps it worked lose and fell off otherwise a rod end should not fall out.
   / B7800 Joystick flopping around #7
Agree that no jamb was there from that pix.
Were it me I'd have used a good lock washer and perhaps even Locktite. (or epoxy)
   / B7800 Joystick flopping around #8
That stud looks bent, and the hole munged up a bit. Perhaps there is something more going on, or something happened in the past to damage it?? You may want to replace that rod end when you get a chance.
   / B7800 Joystick flopping around #9
Just get a new ball joint, helicoil the old threads, make sure the float is working right, then your good to go.
   / B7800 Joystick flopping around #10
Wore out three loader control valves on a Kubota B7100.
You should be able to fit a lock nut on the swivel joint.
John Deere 6120M (A57148)
John Deere 6120M...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2018 Ford F-350 (A55973)
2018 Ford F-350...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
Schulte XH1500 Series 4 Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
