SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,619
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Im guessing the pin is bowing significantly and the boss sees extremely high stress from the bore trying to make the pin stay perfectly straight. Stresses would be highest with a new and tight bore - like yours. How wide spaced are the BH ears in comparison to the width of the cyl rod pin boss?
I cant tell (or see) the extent of bracing around the ears where the pin connects the cyl rod to the dipper. The ears look pretty thin, and unless doubled by some more plate welded in where I dont see, there may be more flexure allowed than is prudent. Flexure will compromise support of the pin. Those hefty bosses in the ears are supported way out at the ear metal itself, so unless the ears are buttressed in some way the bosses offer little support of the pin inside the ears themselves. If the pin bows much the splitting forces on the new/close fit failed part are huge - - and may be a primary contributor. Hopefully that cyl rod eye/boss was just defective.It's not tight, about 1/16th on either side. The pin looked fine, no issue removing it.View attachment 713639
