backhoe strong enough?
   / backhoe strong enough? #31
Look under build it yourself section i posted a few pics of the thumb i built for my 3550 Ford hoe. haniest thing in the world. Out of all the older contractors here with new hoes i get most of the light demolition and shrub removal. handy for placing ornamental limestones, logs rail road ties and various projects.
   / backhoe strong enough? #32
Don,
I have a Woods 7500 backhoe on my Kubota B2910 and am also well familiar with the ability of the hoe to pull the tractor around. Our clay soil is filled with rocks too, so I think we have similar digging situations. Some things I've learned:
As soon as I feel the tractor move, I let off the backhoe controls and try to reposition the bucket to get a different "bite". Sometimes this requires several smaller bites to uncover the rock enough to pry it out and remove it.
If the tractor set-up does shift, you can often reposition it by using the hoe. Use down pressure on the boom to lift the stabilizers and rear wheels of the tractor and the dipper and/or swing to put the tractor back where it was. I have a sub-frame on my tractor, so I feel pretty comfortable doing that, I don't know if that's a good practice without a sub-frame. The Deere hoes, from what I've seen and read, are a pretty nice set-up so I don't think that should be a problem.
As others have suggested, I position my loader bucket in full dump position and lowered to take the weight off the front wheels.
There have been times when I'm surprised how much "trouble" the hoe had removing a rock. One time it looked like I could just pick it up and pull it out myself...so I tried it. It wouldn't budge. It's amazing how much force is necessary to pop some of these things out of the ground.
I now just take my time, and realize that however long it takes to dig with the hoe, it'll be much faster than using a pick and shovel.
~Rick
   / backhoe strong enough? #33
Amen!
   / backhoe strong enough? #35
Tracy, While in the decision making process about a year ago... I questioned the board not only on brand recommendations of tractors... but what size implements (and brands) to get. There are many arguments on what color tractor to buy... Green, Orange, or Blue. All are good but the universal recommendation was Bigger is Better when it came to the attachments. Biggest Loader... Biggest Backhoe you can get/afford. Now owning a JD 4310 with 430 Loader and 48 BH... I'm glad I went with the bigger options! My recommendation to you is 1) go with the brand! 2) Go with the larger JD 48BH! You'll be glad you did!
JOHN DEERE 700M LOT IDENTIFIER 35 (A53084)
JOHN DEERE 700M...
2011 CATERPILLAR 12M MOTORGRADER (A51246)
2011 CATERPILLAR...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
