Bad day of hay making
   / Bad day of hay making #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
You know its a bad hay making day when it takes 15 gallons of hydraulic oil to make it through the day. I replaced the seals on bale density cylinders the next day :) At least we got 96 bales off of 24 acres.
   / Bad day of hay making #2
Will animals even eat that much oil soaked hay? (I am only teasing)
Yeah it sucks when you go through that much oil. I am glad you got it fixed though.
I am also glad you got in some hay too though. That is about average for us too, roughly 104 round bales on 25 acres. I could probably get some more if I fertilized, but at $850 a ton, it kind of makes a farmer hesitate, you know? I will have too next year, it has been three years since we fertilized one particular field, and it is starting to show. Soil tests called for (3) ton of 10/10/10, but thankfully no lime.
Based on your picture, I think your experience was little more peaceful. Nice looking place!
   / Bad day of hay making #4
Looks like wheat straw to me....:)
I go by the philosophy that 'It never breaks in the barn'.... Maybe it's time to upgrade if you are loosing seals. I tend to turn over my bailing / raking equipment every 5 years or so.
The grass is Texas winter grass and first cutting coastal bermuda. That's why it doesn't look "premium". We round bale the first cutting for our own cows and then sell the second and third cutting to horse owners as square bales.
I think it would be hard to justify going from a paid off baler to making payments on a $45K machine. This is really the first time its caused any trouble.
   / Bad day of hay making #6
One thing I've found with hay equipment and that is, as it gets older, the frequency of breakdown's increase., so I run them 5 years and get a new one. Because it's a business, interest is deductible and so is depreciation. The oldest piece of equipment I run (besides my tractors is my HS rotary rake and it's going this winter. Going to buy a new Kubota rotary rake.
Additionally, not going past 5 years is, resale is always good (I never have any issue selling equipment, there are always buyers for used hay tools in good shape so the value always offsets the new price) and advancements in equipment is nice too.
Just peruse forums like this and you'll see that there are a ton of would be haymakers out there looking for used tools.
My NH450 is completely computer driven. It's like playing a video game and it does everything by itself, all I have to do is stop and eject (when it tells me to). Next year is it's last year. I may go Kubota (Vicon) on the next one, not sure. I've always ran NH balers but I may change it up if I can get the deal I want.
Demo'd one this spring. Nice unit but I don't much care for the in cab monitor. The NH monitor is much more user friendly. The Kubota round baler is similar to a Claas, it produces a soft center bale, easier to spear than the NH hard center bale. The one I demo'd listed for 35 and that is twine and net just like my 450. I bet I could get it for 30 if I wanted it.
One nice thing about the NH is I can switch from twine to net on the fly, even if a bale is forming.
Paid off is fine but the older they get, the more issues they have.
No Bermuda grass here, all alfalfa, and timothy. Sorry if I insulted you. Looks like wheat straw. I contract bale that once in a while. Mostly run small squares in wheat straw. Local road board buys them for mulch.
I own a JD discbine that I keep as a backup, just in case. Only green I own. Everything is green here for the most part except hay tools. Those are mostly red and yellow.
   / Bad day of hay making #7
I might add I don't ever use that cheap 35 buck a pail 334 crap either. All my hydraulics (tractor and implements) either get Chevron All Weather THC Synthetic or Shell Rotella VG Hydraulic oil. That cheap stuff is no good for seals or gear drives in tractors not only is it detrimental for seals, it don't contain the proper anti-wear additives for gear drive transmissions and wet clutches.. In fact, if I'm not mistaken on a new tractor or implement, using that stuff will void the warranty. Not something you need to be concerned with but none the less, it's junk.
Chevron is a jobber product only but the Rotella can be bought at TSC (if they have it in stock). Chevron is about $110.00 a pail and the Rotella is around 60 a pail.
Tractors run Chevron only. They are older so maintenance is everything. Have no desire to run an emissions tractor.
   / Bad day of hay making #8
Dang I bale with old equipment. My JD 4255 tractor I bale with is a '91 with over 11,000 hrs on it,my JD 467 baler is '05 with over 26,000 bales on it,My Krone cutter is 10 yrs old,my H&S Hi-cap 14 wheel rake is '02 model having raked 1000's acres but none of my equipment has any red & yellow paint on it.
   / Bad day of hay making #9
Some people luck out, some get screwed. If you take care of your stuff, should be few issues, if you don't (like most people don't), then there is issues.
Think I'd use the Kubby instead of the JD. I bet the GPH on the Kubby is a lot less.
Thing I find somewhat amusing is that when someone gets into what we do, they buy old clapped out, run hard and put away wet equipment, primarily because it's cheap and then when it pukes in the field, they don't have a clue what to do to fix the issue (so the get on forums like this one and beg for help). What is really good is when it pukes and there is rain coming...
I've seen that play out many times.
I use the 5 year rule of thumb. Works for me and my accountant.
Like I said, other than tractors. I won't touch any Tier 4 final tractor. One, I'm not evviromentaly correct (I like diesels to smoke when working) and two, at my age, I have a certain disdain for electronics, especially lowest bidder emission electronics.
   / Bad day of hay making #10
5030
I utilized my '11 Kubota M7040 when AC compressor was out on my JD 4255 last year. I pulled my rd baler with the Kubota(64 pto hp) tractor until I replaced the compressor. I have checked my JD fuel consumption on my 4255(127 pto hp) before AC quite. JD 4255 used 3.2 gph while M7040 used 2.5 gph so .7 more gph for twice the pto HP. I'm similar to you in not liking the new newfangled electronic wizardry or payments as my farm equipment has been paid for for many yrs.
Jim
44052 (A55852)
44052 (A55852)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
19008 (A56859)
19008 (A56859)
