Bad Sunday
   / Bad Sunday #11
Try a VERY large screwdriver. Tap it into the broken off piece and use a wrench on the driver flat.
OR, the tapered end of a file, same Technic.
Work it both ways at first to loosen then unscrew.
   / Bad Sunday #12
you want the internal pipe wrench , E Z outs will expand the pipe and may make it very difficult to remove,
the best type of internal pipe wrench I have found is the one with three tabs that expand internally and grip the pipe that way, Proto makes them, the one with the ring that revolves works too, but not as strong,
   / Bad Sunday
1/2'' id. Thank you ace has the stud wrench, which is 1/2 and 3/4, I will look at the internal pipe wrenchs too. Thanks!!
   / Bad Sunday #14
If you broke it off it means it's one of the plastic pipes with the twist lock cap on the end. Being plastic threads they won't be a problem getting out. A pair of scissors of adequate size tapped in there with a hammer should do it. I'd only use one of the blades.
When replacing with metal pipe and pipe cap, teflon tape on the threads, get the pipe long enough so that you can put your oil drain pan under the "spiggot" and forgo the usual mess.
Mark
   / Bad Sunday
Its that cheap white metal.
Texasmark I saw people do that after I ordered the parts. I have a bucket that catches it all. Appreciate it.
   / Bad Sunday
I bought the internal pipe wrenches. I had to use a step bit to drill out the tube a bit but once that was out the internal pipe wrench worked like a charm. Now its just replacing parts....the weather is getting cold and I hope to cut the grass one last time. Thank you all for your help.
   / Bad Sunday #17
I had a neighbor who had the pipe break, when he was changing the oil. He's not particularly handy, and was apparently tightening, rather than loosening. I used an EZ out, I think it was a #5 or #6 (I have collected some rather big ones), and walked it right out. I used some brake cleaner to get the oil off, so that the tool would "bite" better. I have some large sized IRWIN pipe equivalents, but have never tried them. They have six point heads, and sockets work with them.
Also, you could use a hacksaw blade or a jugsaw blade to partially cut through the pipe, and give you a better grove to fit a slotted screwdriver into.
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
(UNUSED) NEW HOLLAND C332 SKID STEER (A51242)
(UNUSED) NEW...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2021 KUBOTA U55-5 EXCAVATOR (A51242)
2021 KUBOTA U55-5...
