Bad vibration/ Kubota RC72R-F30 deck
   / Bad vibration/ Kubota RC72R-F30 deck
ZZVYB6, Can you explain a little more in depth for the dummy in the room? ;)
Are you saying that in my case I do need to maintain the factory positioning. Keeping the gearbox input parallel with the tractor output?
Another question:
I thought about hitting up a drive shaft shop to see if they can build me a new shaft/yoke setup. If they can do it would it be beneficial to use CV joints instead of U Joints? Just thinking out loud here.
   / Bad vibration/ Kubota RC72R-F30 deck #12
Bad news from Messicks. All of the parts for my PTO shaft are discontinued from Kubota.
...................snip.......................
I discovered the same situation regarding discontinued parts earlier this summer.
My Kubota RC72R-F30 deck in F3060 mower uses Weasler Engineering Series 6 drive shaft parts and I was able to find drive shaft repair shop who is Weasler dealer nearby where I live.
They made me all new drive shaft for just over $400 and it works great.
Afterwards I went ahead and ordered another set of parts from online dealers and built another PTO shaft out of Weasler parts, just to have a spare shaft.
Here is my posting in TBN Kubota Lawn and Garden section last month:
Kubota F3060 PTO Shaft - OEM Replacment No Longer Available!
My mower has very similar setup as you have, and looks like may have the same Superior 90 degree gearbox with offset mounting like you have.
The PTO shaft had served the previous owner about 3500 hours so I would suggest just getting it repaired and stick with the original design!
I also replaced the 90 degree gearbox last minth and posted about that here:
90 Degree Bevel Gearbox on Kubota F3060 - 72" Rear Discharge Deck
Nothing wrong with the OEM Superior gearbox in my mover, but I wanted to eliminate the shear bolt yoke setup in the gearbox end and will have a keyway machined into the input shaft. I also wanted to have a spare gearbox since it only cost about $140
They are easy to find on the eBay.
  • North-American-Style-Driveline-Components-Aftermarket-Product-Guide.pdf
Damn! Why couldn't I find your thread earlier?
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
FRONTIER FAV20 LOT NUMBER 64 (A53084)
FRONTIER FAV20 LOT...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2020 JOHN DEERE 6145M LOT NUMBER 74 (A53084)
2020 JOHN DEERE...
