RickB
Super Star Member
- Joined
- Sep 18, 2000
- Messages
- 15,143
- Location
- Up the road from Dollar General WNC
- Tractor
- Just a Scag
Im not understanding. This sounds impossible. The needles go thru the bale chamber very quickly while the ram is backstroked. They must flip back down out of the way to allow the ram an unimpeded forward stroke. For preservation of the needles there is a mechanical safety that sticks up into the bale chamber while the needles are up. This stops the ram dead and shears the bolt. The flywheel continues but the baler is NOT running.
You can observe and trace the motions while turning the baler by hand. When you trigger the knot cycle will delay until ram is on its backstroke. The needles come up while the knot ties and rethread the knotter - then recede quickly as the ram comes back toward the chamber. At running speed, if the ram comes back into the chamber before they are clear they are destroyed. Trace all the drives at hand speed and youll find a loose or sticking or broken part. Then everything will be ok.
larry
Nonsense. The needles travel through slots in the plunger face and cycle when the plunger is rearmost in its stroke. The plunger never touches the needles, and without hay, sticks, or other debris in the chamber, there is no possible way that the plunger can break the needles.
