Ball Size
   / Ball Size #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I'm looking at buying a 16 foot bumper pull stock trailer and I'm not sure that I understand the significance of the two sized available for the ball. Some say they have a 2 inch ball, others are 2 5/16. I understand that bigger is better, but why? Does one hold more weight? If it has the smaller 2 inch ball, wont that be enough?
Thank you,
Eddie
   / Ball Size #2
It depends on the gross weight of the trailer. The capacity of the ball should be stamped on the ball. If you have an accident, and the hitch was to small for the load, you could have a major problem with your insurance.
   / Ball Size #3
As long as its rated for the weight, the only advantage to the 2 5/16" over a 2" is that less friends will be able to borrow that trailer.
Aaron Z
   / Ball Size #4
2 5/16" seems pretty standard for any serious trailer... And they can be rated much higher (if it is the right material/design). I would stick with it.
   / Ball Size #5
Aaron Z
Are you saying size matters?
   / Ball Size #6
If you really want to keep friends from borrowing your trailer, go with ring and pintle :D Or even better the Euro Ringfeder style ring hitches. Self aligning hookup FTW!
Im only partly joking. Eventually Id like to have all my trailers with rings. Was looking at these guys products and if you use their rings and pintles, there is supposed to be less play than normal.
   / Ball Size #7
Reads more like he's writing the strength of your balls matters.
Eddie -
First - you should have both size ball's. I've a 2 5/16 trailer but occasionally pull U-Hauls etc., which are 2". Bigger balls are better.
Second - what's the GVWR on the trailer - make sure your balls exceed that, but I know from experience that finding a 2 5/16 ball w/ a 12K plus rating is difficult at auto stores and Walmart, easy on-line.
And third get rust resistant balls, there's nothing worse than having cruddy balls except having cruddy weak balls.
Investing in an extra ball is only about $10, for an extra $10 I'd rather have 2 balls than one.
And pay attention to the size of your shank, make sure it's 1 inch and your balls fit.
For the trailer I don't think size matters, as long as it's a low GVWR trailer.
   / Ball Size #8
2" balls do not come in the higher GVWR ratings.
One drawback to 2-5/16 hitches is that it is possible AND DANGEROUS to hook them up to a 2" ball by accident. You can't do it the other way around.
If the trailer sits at the right height, one of the "3 way" inserts with 1-7/8, 2, and 2-5/16" balls is great to have and solves the issue. Of course, many trailers require a drop hitch to sit level.
   / Ball Size #10
Eddie -
From what I have seen, in a 1" shank class, both 2" and 2 5/16" are available with ratings up to 12,000#. To get a higher rating, you have to go to a larger shank (such as 1 1/4") and there you can get ratings up to 30,000# for a 2 5/16" ball.
If it were me, and I got a trailer that needed a 2 5/16" ball, I would get a ball mount for it so that I didn't need to swap balls because that it just a pain in the neck so do.
Aaron Z
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
377811 (A48836)
377811 (A48836)
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
