Ball Size
/ Ball Size #31
Eddie, the CM Stocker trailer, 16 foot, like you said you wanted, comes with brakes on both axles if you get the 5200# axles and it has a 2 5/16" Bulldog hitch. That is what I have and it is great. The trailer brakes my Dodge Ram 2500. I bought it used from up near you, in Mt Pleasant, about 5 or 6 years ago.
/ Ball Size
After doing some looking at trailers yesterday, I think I'm making a mistake with a bumper pull stock trailer. They are just too tight for horses, and I'm not comfortable with trying to make it work. I've decided to get the B&W turnover gooseneck ball for my truck bed and install it myself. Then I will buy a 3 horse slant load gooseneck trailer. Probably used, and probably aluminum.
I think for the long term, this will be something that I will enjoy having instead of regret buying.
But back to ball size, I am curious why the pin that attaches that hitch isn't brought up? Seems to me that it is the weak link to everything. I would expect it to sheer before something happens to the ball.
Thank you,
Eddie
/ Ball Size #33
Whatever you decide on, with an F-150 you should look at a trailer with brakes on both axles. Figure three horses would weigh around 3000 to 3600 #, add the weight of the trailer. You want all that weight controlled by the trailer.
Can't answer your question about the hitch pin, but you are right. It does seem to bee the weak link. Someone out there knows.
/ Ball Size #34
<snip>
Thank you,
Eddie
I think you will be happier with the gooseneck.
Concerning the "pin" that attaches the hitch do you mean the shank on the ball?
Those also are normally thicker for heavier duty balls and are usually part of the ball (not always).
For example 2" balls come w/ 3/4 and 1" shanks. I guess generally bigger balls, bigger shanks.
/ Ball Size #35
I think he means the pin that holds the ball mount into the receiver? If so, this was discussed a while back: http://www.tractorbynet.com/forums/trailers-transportation/182179-hitch-pins.html
Aaron Z
/ Ball Size
Interesting thread. It sounds like the pin is plenty strong enough for anything you can pull.
Eddie
/ Ball Size #37
After doing some looking at trailers yesterday, I think I'm making a mistake with a bumper pull stock trailer. They are just too tight for horses, and I'm not comfortable with trying to make it work. I've decided to get the B&W turnover gooseneck ball for my truck bed and install it myself. Then I will buy a 3 horse slant load gooseneck trailer. Probably used, and probably aluminum. I think for the long term, this will be something that I will enjoy having instead of regret buying. But back to ball size, I am curious why the pin that attaches that hitch isn't brought up? Seems to me that it is the weak link to everything. I would expect it to sheer before something happens to the ball. Thank you, Eddie
It takes about 55,000# of force to shear a 5/8" non hardened hitch pin. You will break the hitch itself before the pin.
Chris
/ Ball Size #38
The pin is in double shear - there is no better mode you could ask for, from a mechanical engineering standpoint, for metal parts. And frankly it is in double shear in 2 places, so the load is reduced by half on each side. The pin is typically not going to be an issue...
/ Ball Size #40
Quite right Dave!
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
TULSA WINCH (A60736)
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2016 Terex RL4 Towable Light Tower (A60352)
2016 Terex RL4...
