Bare-bones tools necessities for "home" shop????
   / Bare-bones tools necessities for "home" shop???? #21
A good workbench and a solid vise is where I started and added to it as projects required additional tools.
I can't emphasise how valuable a good vise is!
rankrank1,
I have a few questions for you concerning this part of your post:
(Note: With the buzzbox you can obviously weld, but you can also heat metal and braze with it using a twin carbon arc torch which can be made for next to nothing or you can buy a used one for about $60 and you will not have to buy an expensive oxy/acetylene gas set-up. You can cut metal with it by soaking 6011 rods in water, use carbon rods, or even power a small gouge system like an Arcair if you have an air compressor. You can also weld aluminum pseudo-tig style if you can master the twin carbon arc torch head mentioned earlier. Granted none of these are the absolute best tool for the job, but they will work and do it very cheaply which is perfect for the home hobbyist).
I think I've seen someone using a setup similar to what you are calling an Arcair. They were cutting apart a Bobcat bucket for reworking. Does this form of cutting steel give you a smoother edge than an O/A torch?
Second, do you have a link to view this Twin Carbon Arc torch you mention. I think I had that and the Arcair, in my mind, as being the same thing. Yet from your post, they seem to do very different things. The TCAT seems to be a substitute for an O/A torch, if I'm understanding you correctly.
Thanks for helping me grow my knowledge base.
   / Bare-bones tools necessities for "home" shop???? #23
I was wondering what some of you master fabricators would deem as the bare minimum in the tools department to have in a "home" shop considered usable/capable of fabricating low to mid-level challenge projects?
I know that what some consider a must have others might call a luxury. That being said, there is going to be overlapping areas of needed tools that all agree are really necessities of a truly functional shop.
Lastly, if looking for quality, used tools, what kind of a budget would you guesstimate to furnish said shop.
Thanks to all for their time and comments.
Start out with a good 4-1/2" angle grinder--the essential tool for any metal work (cutting, grinding).
Then get yourself a 220V/200amp AC/DC stick welder (mine is a Hobart LX).
Get a good auto-darkening welding helmet (mine is a $60 helmet from Northern Tool).
The get a bunch of clamps, magnetic holders, brushes, welding hammer etc.
Next, a horizontal band saw.
Then a floor type drill press.
Then a good air compressor with hoses, nozzles and assorted fittings. This gets you into the wonderful world of pneumatic tools (which usually are less expensive than electric equivalents).
   / Bare-bones tools necessities for "home" shop???? #24
Don't forget the obligatory 55 gallon drum full of metal scraps...never throw away a metal scrap, no matter how small.
Mark @ Everlast,
This question is for you.
I have an old Lincoln AC 225 welder. I keep reading about DC welders and how people say that once you've used one, you'll almost never use/need AC again.
It was free, so I can't complain; however, what kind of cost is one looking at to "eat the greener grass of DC"? What size and voltage will be able to handle any sanely sized projects I might undertake? Are used one easily found and if so what does one look for as warning signs it's been used and abused?
Thanks for your 2 cents on this.
   / Bare-bones tools necessities for "home" shop???? #26
I keep reading over and over about HF or Harbor Freight.
First, I am assuming that the initials are referring to the latter.
That being said, my question is this. Is this a brick and masonry store or just an online retailer? If the former, what states/areas of country are they located in?
Seems like they have a loyal following but also generate a "love them, hate them" attitude towards what they sell. It seems that their price point is their greatest asset.
Thanks to all, taking lots of notes on this one.
BWD,
Harbor Freight (aka Horrible Fright) is an importer of cheap chinese tools, w a few American ones thrown in the mix. Very few. Years ago they were a catalog seller. Now they do online, catalog, and brick/mortar. Go to their website and use the store finder to find one near you.
I use them to buy toools that I either need for one job or tools I think I want but not sure enough to buy expensive ones. If it turns out that I like/need it, then I will buy the quality tool after the HF wears out. Which can be pretty quickly in a lot of cases. Once in awhile you'll get one that lasts.
   / Bare-bones tools necessities for "home" shop???? #28
Mark @ Everlast,
Big Wave,
There is a lot of difference in the welding arc and the quality of weld. The DC arc is generally more soft and stable. Until you weld with DC you don't know what you are missing.
Having DC means that the AC is converted into DC if it isn't a brush type generator, either powered by an electric motor or engine. The brush type generators are known to be the best of the best, and most of them are quite old now...Because it is expensive to manufacture and all the welding mfg'rs have figured out that they last indefinitely and that pinches their pocket book.
Enter Buzzbox welders with AC/DC current. These use the AC to convert to DC with rectifiers. They are usually much lower output on DC than AC, because of the conversion process. Duty cycles are not great either on the low end welders.
Lifespan is decent if they are handled and used correctly. But they offer little flexibility and are heavy to carry around and guzzle electricity.
Enter DC Inverters. I have talked to a lot of people about this, since this is what I sell. Many guys have still never welded with one. But the way the inverter is able to handle certain welding situations adds a different feel to the arc. Inverters are capable of "tuning" the arc because the arc is electronically generated. With DC transformer welders, as the arc gets tighter, the voltage drops and the overall watts required to burn the rod drops so the rods can stick. This requires a longer arc. The arc voltage then comes up and the watts increases....The problem with this is that longer arcs in some situations, especially out of position welds are not desirable because of weld contamination and lack of control of the arc, and mainly a stuck rod.
IF an inverter is so equipped, like the Everlast, the unit has arc force control. This, in the simplest terms, boosts the amps as the arc length shrinks....and the voltage begins to drop. The increase in amps is done synergically, in relation to the the arc length. This helps to maintain overall wattage and keeps the rod burning, even if it is held directly in the puddle. This means that the welder can be run at lower amps and it can offer a more controllable puddle, as the unit compensates to keep the rod burning even if it seems a little cold. This also helps prevent the formation of heat affected zones while welding, by running cooler.
Not all inverters have arc force control, but this is a definite advantage.
Inverters also can boost the starting ability of the rods with a "hot start" feature which sends an extra surge of current when the arc is struck preventing the sticking of the rod to the metal. There again, not all have it.
But even without the arc force control and hot start, the DC inverter can be made to mimic the old brush machines, where as the cheaper transformer DC machines are not as stable or as robust... Their DC arc is still better than any AC arc though.
The lifespan of inverters have been in question, thanks to early inferior designs. But with the addition of soft switch technology which makes the part of the welder that creates the arc last much longer. These parts that make the welding arc are called transistors..They are classified as IGBT or MOSFET. The IGBT's are the quarter horses of transistors, while the Mosfets are the thorough breds. Most welding companies have chosen IGBT's because of their ability to be abused, though they aren't quite as nimble. MOSFET units tend to be extremely lightweight, in comparison to equivalent IGBT units that I have found. They weld great, but I have seen, especially with the imported welders issues with the MOSFETS durability. But current IGBT's all seem to be fairing much better in dire conditions.
I don't guess I have directly answered your questions yet, but I wanted to give some very broad background.
The DC welders are more...but the price is across the board.. Our DC inverter is 350.00, other brands for similar level of performance are over 1000.00. But to get the best range of performance, I think you will need about 200 amps, but you could survive with 160 which would allow 5/32 rods.
Mark,
The DC Converter that you sell for $350 and that is 200 amps, does it use 220V AC? Also, if it does, then what size circuit does that welder need, 50-80-100?
Thanks for the background. It's quite useful in flushing out the picture of welders and what they can do and how they go about doing it.
   / Bare-bones tools necessities for "home" shop???? #30
Something to drill with.
Something to cut metal.
Something to weld metal.
I would add something to grind and bend metal with. You can cut and weld with an O/A torch. You don't need an electric welder. With a Henrob 2000 the torch cuts almost like a plasma cutter.
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55302)
2012 Ford F-150...
2019 ROCK LINE RS8-32 80" X 9' HYD DROP DOWN TRAIL (A52706)
2019 ROCK LINE...
2017 BOBCAT T650 SKID STEER (A52707)
2017 BOBCAT T650...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
2016 Ford F-550 Altec Bucket Truck (A55852)
2016 Ford F-550...
