Barns and shop layouts
   / Barns and shop layouts #31
Paul B - yup, strange it is. It's at least 20 years old - it needs a high-speed rear pto which is getting rare these days. My tractor didn't have one so I <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=owning&Number=102451&page=0&view=collapsed&sb=5&o=&fpart=all&vc=1>ADDED A 2-SPEED PTO</A> a couple of weeks ago.
Only other pull-type snowblower I've seen was made by Normand (Canada I think) and was 2-stage, 7 feet wide.
Dick,
How do you open those 18ft doors? In another photo, I thought I saw an automatic door opener (right/wrong)? If you are useing a door opener, how'd you set it up off center of the bay with the lift?
   / Barns and shop layouts #33
Hi Peter - the openers are Chamberlains. Each door is 18' x 7 1/2' - and has a torsion-spring winder. On torsion winders, the cable reels are on a common shaft, so doors of any width run level. On the lift bay, the opener is well off center and the torsion spring anchor is too. The door works fine - even without the opener, a few pounds anywhere on the door will send it up.
To get the door out of the way when open, I considered sloping the upper tracks - but that would have meant 9 or 10 scissors trusses and too much attic space lost. By placing the lift posts 20' from the door, only the longest vehicles need the door lowered a bit for clearance.
Hmm, that gives me some ideas for my existing door and the for the 12x11ft door that will go in the new barn.
Thanks
Peter
   / Barns and shop layouts #35
There's a NH dealer on my to work with a small Boomer that has pull-type blower on it. I'll see if I can get the name of it. By the way, it's red.
   / Barns and shop layouts #36
There's a red Canadian brand I've seen photos of on AgDealer - the brand is Normand. It was a pull-type but may have been altered?
   / Barns and shop layouts #37
I did a search this morning - <A target="_blank" HREF=http://www.cienormand.com/soufnina.htm>not altered</A>. But the one I saw was smaller than this.
   / Barns and shop layouts #38
I am always on the lookout for ideas that I can borrow. When we were looking for a new property we came across one that had a full length drain across the front of the garage. I tucked that idea away as I thought it would be useful some day. Well the property we bought needed some development and one of the things I did before we paved the driveway was put a concrete apron on the front of the garage that has a full length drain. This collects the water coming from the crown of the driveway and also collects the water from the garage does does not go into the floor drains. I find it works very well so I thought I would share the idea with you.
   / Barns and shop layouts #39
Paul - thanks for the link - that Normand is a big unit - cuts 92" width. I emailed them to ask if it's available in the states. I'm also looking forward to knowing more about the smaller one you saw. Hope you'll have a chance to check it out.
   / Barns and shop layouts #40
I need something like that. Are the gutter and grates something you can buy prefab or do you have to build them yourself?
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
FUEL CELL (A58214)
FUEL CELL (A58214)
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
