Basement Concrete Wall Paint
   / Basement Concrete Wall Paint #11
We dry locked it, along with running all gutters and downspouts the right way our basement is very nice now.
   / Basement Concrete Wall Paint #12
If you have water issues - no off the shelf paint will correct the prob. A couple of coats of the UGL or Zinsser will give a marginal safety net. I have used the UGL and topcated with a bright white gloss for cleanability in a few houses - no issues in the past 7 years. Be sure to mix the paint before and during to keep the solids in suspension.
No water issues other than condensation in humid weather.
   / Basement Concrete Wall Paint #14
Like I mentioned earlier, I usually steer people away from those waterproof paints. I've seen condensation increase on one customer's walls, she said she never had a problem before she had the walls "waterproofed"
Most basements do need a dehumidifier in summer months regardless of active leaks or not.
JB
JB
I have seen the same thing with an oil base paint and then the paint peels off. I was actually looking for a breathable primer and then indoor breathable paint. I am going with the Zinsser Bulls Eye 1-2-3 primer not sure on the paint yet.
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Service Truck (A55973)
2015 Ford F-350...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
E-Z TRAIL S10 GRAIN CART (A52708)
E-Z TRAIL S10...
Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
Sterling T/A Ox...
