Careful with the math. Your Tesla in-vehicle reports Wh
from the battery, not from the grid.
You need something like TeslaFi.com or a power meter on your home EVSE to be able to calculate actual power use and cost.
EPA invented a silly MPGe for energy equivalence of ICE vs EV. Based on 33.7 kWh/gallon of gasoline. Your calculations are of what I consider more relevant, MPG$, MPG equivalent based on cost. I have stated many times I believe the $ cost of goods is the most accurate unit for comparing resource consumption. If it costs more then the resource was more precious and/or consumed more labor.
This is what I did:
Yep BUT I did fudge the numbers in the Tesla phone ap.
Our KWH charges are .10- .116 from the utility and All the calculations are done @.12 that was entered in the phone ap, so I built in a bit of safety margin on charger losses, battery heating, etc.
Maybe not enough. I should get an inline data unit eventually.
ps. bumped up the calc. cost to.13 per KWH and updated the MPG in above post.
That should be a ~17% for waste/losses.
Another update,
decided to check out the local ORV park (wanting to test out the old dirt bike) and did a 47 mile round trip with most of it state hiway @ 64 MPH and a bit of slow speeds -35MPH on the back roads.
local gas jumped again to $3.96 for regular 87 octane.
123 miles per gallon equivalent for todays trip.
Liking these new non rubber band tires and snow wheels.
Tesla could increase their range on the Model Y by going to 18" wheels and high efficiency tires.
Think the math is right since I am upping the KWH cost to make up for the lower KWH used as reported in the trips card..?
It does seem to be going over 4 miles for each KWH.
Also these tires are taller than the stock tires by a little bit, which should under report miles travelled slightly.
The math does seem hard to believe but expensive gas and cheap electricity changes things.
