WinterDeere
Elite Member
Fires resulting from use of extension cords at 400 - 500 watts likely have nothing to do with wire gauge, and everything to do with cordset condition, including plugs and receptacles. Use a chewed up cord in a loose receptacle, and you're going to increase your likelihood of fire, no matter what gauge of wire was used in the making of that cord.There are many "Block Heater" Vehicle and sometimes Home Fires, up here in Canada. The first thing an Insurance Adjuster looks at is the Extension Cord... And a Block Heater is only 400-500 watts
That said, some block heaters are rated as high as 1500 watts. Those would require attention to the gauge of cord used to connect them. It's likely your observance of fires related to block heaters is related to some combination of damaged cords and these higher-wattage heaters that actually do require heavier cords.
