battery for JD 3010 diesel
   / battery for JD 3010 diesel #1
John Deere 112, John Deere 3010D
I have an arrangement to purchase a John Deere 3010 diesel that has been sitting unused for 7 years. The person selling it knows nothing about it. The batteries have been removed. I have heard conflicting info about which batteries it takes. Is it two 6 volts? Or two 12 volts? Any other comments on this machine would be welcomed as I don't know a lot about this model.
Thanks
   / battery for JD 3010 diesel #3
All of them that i have seen take 2 6 volt batteries hooked up in paralel to give you 12 volts.
   / battery for JD 3010 diesel #4
I have not been here very long, but in my book, 2 six volt batteries in parallel give you six volts... Just sayin....
   / battery for JD 3010 diesel #5
Give me the correct word then please. You know what im talking about. Thought it was called paralell. - on one battery to frame. + on same battery to - on other battery. + on second battery to starter. Equals 12 volts. Whats the correct phrase? Is it "in series"?
   / battery for JD 3010 diesel #6
Didn't mean to be a smart arse.... The connection you describe is a series connection. It will give you 12 volts from the last connection to ground.
   / battery for JD 3010 diesel #7
Thanks. I just had the wrong word.
   / battery for JD 3010 diesel #8
Nobody has the correct answer yet, even Tractordata (no surprise there). 3010D tractors ALL left the factory with 24V floating ground systems. They use two 12V batteries that are, I believe, BCI group 3EE. Many of these tractors have been converted to 12V negative ground.
   / battery for JD 3010 diesel #10
I agree with Rick on this make sure what configuration your tractor has before firing it up.
2016 Ford Transit 250 Cargo Van (A56858)
2016 Ford Transit...
2025 AGT MX12RX Mini-Excavator with Pilot Controls & Dozer Blade (New/Unused) (A59225)
2025 AGT MX12RX...
1987 Chevrolet R3500 (A57148)
1987 Chevrolet...
2019 PJ 40FT GOOSENECK TRAILER (A58216)
2019 PJ 40FT...
2020 CATERPILLAR 259D3 SKID STEER (A52709)
2020 CATERPILLAR...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
