battery for JD 3010 diesel
   / battery for JD 3010 diesel #1
John Deere 112, John Deere 3010D
I have an arrangement to purchase a John Deere 3010 diesel that has been sitting unused for 7 years. The person selling it knows nothing about it. The batteries have been removed. I have heard conflicting info about which batteries it takes. Is it two 6 volts? Or two 12 volts? Any other comments on this machine would be welcomed as I don't know a lot about this model.
Thanks
   / battery for JD 3010 diesel #3
All of them that i have seen take 2 6 volt batteries hooked up in paralel to give you 12 volts.
   / battery for JD 3010 diesel #4
I have not been here very long, but in my book, 2 six volt batteries in parallel give you six volts... Just sayin....
   / battery for JD 3010 diesel #5
Give me the correct word then please. You know what im talking about. Thought it was called paralell. - on one battery to frame. + on same battery to - on other battery. + on second battery to starter. Equals 12 volts. Whats the correct phrase? Is it "in series"?
   / battery for JD 3010 diesel #6
Didn't mean to be a smart arse.... The connection you describe is a series connection. It will give you 12 volts from the last connection to ground.
   / battery for JD 3010 diesel #7
Thanks. I just had the wrong word.
   / battery for JD 3010 diesel #8
Nobody has the correct answer yet, even Tractordata (no surprise there). 3010D tractors ALL left the factory with 24V floating ground systems. They use two 12V batteries that are, I believe, BCI group 3EE. Many of these tractors have been converted to 12V negative ground.
   / battery for JD 3010 diesel #10
I agree with Rick on this make sure what configuration your tractor has before firing it up.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2013 Ford F-150 4x4 Pickup Truck (A51692)
2013 Ford F-150...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
2010 Ford Focus Sedan (A51694)
2010 Ford Focus...
