Battery repair -- epoxy or silcone caulking
   / Battery repair -- epoxy or silcone caulking
Just a follow up...
I ordered the correct tie-down parts from Messicks (it was only $17, so it wasn't worth my time to fab something up, as I don't have extra metal around to do it, and a trip to Home Cheepo would have cost just as much).
I'm picking up the parts today, and will be back in business to mow; well if the rain will stop long enough for the grass to get dry enough to cut without making a mess of it.
Thanks to all for you help!
Jay
   / Battery repair -- epoxy or silcone caulking #23
I see this is an old thread, but I found it today through google as I have a couple 8D batteries that were punctured in an accident, but were still showing correct voltage, but had two dry cells due to holes. I used a tool I bought from Harbor Freight that is called a Plastic welder that basically blows air through a tube that is heated by electricity and using a putty knife, I was able to heat the surrounding areas and seal the holes up. Melted the surrounding material. Filled with water and no leaks. Went ahead and put them on the charger and they show a strong read on the load tester.
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
WESSEX CRX 180 LOT NUMBER 171 (A53084)
WESSEX CRX 180 LOT...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
