Battery Size Question - John Deere B
   / Battery Size Question - John Deere B #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
Hello!
I just acquired a John Deere B (family heirloom) that has been restored and kept up-to-date. After transferring it home, we did maintenance checks (oil, filter, etc.) and found that the battery doesn't seem to be working very well. The battery is a 5V unit and there was question that it should be a 10V unit - can anyone confirm? I thought about buying a new battery - replacing the one that was in there - but wanted to know if was supposed to be a 5V unit.
We are also in the process of determining the SN/Year - someone painted over the tag and the stamp is filled with green paint (nice color, but we'll need to use a paint remover to get to the original SN). We think this is a '51 model.
Thoughts? Thanks!
-Bob
Hello!
Thoughts? Thanks!
-Bob
Got my answer. It's a 5V (unless you change out parts), it puts + to ground, and although they did at one time make 7.5V batteries you should stick with th 5V.
-Bob
   / Battery Size Question - John Deere B #3
:thumbsup:
A pic or two would be great, and would like to see it.
That 5v was a new one to me.
   / Battery Size Question - John Deere B #4
:thumbsup:
Same here, never heard of a 5V industrial battery. I have used 6 volts, 12 volt and even an 8 volt once to increase the starter capacity on a 12 volt system (one 8 and one 6).
   / Battery Size Question - John Deere B #5
-Bob
Bob
There's no such thing as a 5 or 7.5 volt battery for a automobile or tractor. Each cell(cap) on a lead/acid battery contains 2 volts so if it has 3 cells as your tractor should then it requires a 6 volt battery. Below is a serial chart so you can determine yr model of your B if it has a serial number tag.
   / Battery Size Question - John Deere B #6
lead acid batteries run 2.1 volts per cell, I agree with Jim most likely to be a 6 volt battery. A modern day 6 volt battery will blow away the batteries from the 1950's. Batteries have improved quite a bit over the years. Never heard of a 5v 7.5 or 10 volt lead acid battery either.
   / Battery Size Question - John Deere B #7
A BCI Group 1 battery will fit the box, be 6 volt nominal voltage, and a fresh one is all you need to roll your B over.
Sorry. I have been away. You were correct it was a missed type. It is a 6 V battery. It goes under the seat and fits snugly into the area where the battery is to go.
Thanks!
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A54865)
INOP/NON - RUNNING...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2016 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A56138)
2016 VOLVO VNL64T...
Kubota L2500D Utility Loader Tractor (A55851)
Kubota L2500D...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
