Battery Tender Connections
   / Battery Tender Connections #11
What type of connectors you using? I know the ones that come with them but say if I wanted to snip the alligator clips off and add my own. Something like a flat 2 pin ? Any recommendations?
All my tenders came with a flat 2 pin connector that alow's going back and forth between included clamps and rings. The same configuration plug is available where auto parts are sold. No snip or clip of tender wires required.
   / Battery Tender Connections #12
It's lead; a self-tapping screw wouldn't need a pilot hole :drink:
True, but you ain't got a lot of room for error in the top of a post. I like a small pilot hole when it needs to be 'just so'.
   / Battery Tender Connections #14
That's perfect. But I'd need the other side as well. Call it the male end? Depending how you look at it. My battery maintainers have the alligator clips that I'd have to cut off and put new ends on.
   / Battery Tender Connections #15
This is what I did. Permanently connected leads to the battery that came with the battery tender and installed a quick disconnect panel on my dash.
   / Battery Tender Connections #16
   / Battery Tender Connections #18
   / Battery Tender Connections #20
It's not necessary to connect at battery terminals. I connected 12 ga wire at terminal blocks to install cigarette lighters on my riding mower and tractors. Salvaged lighter plugs connect into the 2 prong plug on tenders. The lighter is handy for phone charger,work light and port for charging test.
I also put a 12v male plug on my trickle charger and a 12v socket on my tractor. I can move the charger to anything that has a 12v hot socket and charge away.
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
Enmark Z Spray (A53316)
Enmark Z Spray...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2020 HINO 268 26FT NON CDL BOX TRUCK (A56138)
2020 HINO 268 26FT...
