Beam size
/ Beam size #21
Thanks for the pics... .
/ Beam size #22
The floor feels solid though I have measured about a 5/8" sag in the middle of the room.
5/8" is almost exactly the nominal L/360 deflection. I wouldn't put any more up there. A hot water heater is heavy, hopefully that's near the edge of the span.
/ Beam size #23
I would conventionally frame the walls and use I-joists or trus-joists. Everything will be straight and you can deck over them for additional storage. I used 25 footers when I did my second story addition. They are carrying the second floor as well as carrying the ceiling from the first floor.
/ Beam size #24
I've built 4 lofts in shops and two houses. Two lofts and one house I used I joists. The one loft was 18' span and I did it all myself with two bad rotater cuffs and a bad back. Exercise room and shelving racks above. Very solid.
Super easy & lightweight compared to using dimensional lumber, not to mention setting a steel beam by your self. I joists are straight, a lot of dimensional lumber is not.
/ Beam size
I'm thinking about the steel beam, like the idea of someday using it with a chain hoist. But whats the best way to hold up the ends. I'm thinking a pocket with just 2x4 stacked to the beam width may not be enough.
/ Beam size #26
Solid wood posts could certainly be used, but also steel lolly column too.
JB
/ Beam size #27
Your building setup will be almost identical to mine (42x69x14). My "room" is only 12x12 however.
I have found that the area above the tool room is IDEAL for long term storage. I wouldn't want to guess how many hundreds (thousands) of pounds I have stored up there.
My advice, spend the little bit extra, and make it useful space. You are probably thinking you will have "all the room you would ever need" with this new building... Funny thing so did I. Bought a new to me Kubota yesterday, and barely had space in my building for it. One of my weekend chores is to see if I can clear some additional floor space. Guess where I will store it - yup - on top of my tool room.
Have fun!!
/ Beam size #28
30 @ 5.98ea @ menards is $179.40 Another $200 for the steel beam and we are in the same price range.
You forgot to add the copay and deductible on his health insurance using the steel beam. I'm guessing hematoma on forehead from running into the beam is most likely (no hardhat), but possibly a smashed foot (wearing gym shoes) or dislocated lower back.
/ Beam size #29
Its only a 300lb beam. That is 150 each end. 2 guys and one side at a time. ~75lbs each????? Whats the issue.
Not to mention alternative methods. Like a tractor perhaps?? I dont know what the OP has but this IS a tractor forum. Or perhaps hoisting using the trusses. Again, its only 300lb
/ Beam size #30
Long term storage!
I know a guy w an auto shop who has his very large industrial air compressor up there over his office. The area is walled off w an access door so sound is not an issue in the shop. Been that way for at least 30 yrs.
I guess you could put the water heater up there too.
/ Beam size
LD1 you said a W10x15 beam would work, is the 10 and 15 inches or some other way to describe the beam? Want to make sure I ask for the right thing.
/ Beam size #32
This is standard beam nomenclature. W="Wide Flange". Some other types are H and S. First number is height in inches. Second number is weight per running foot, sort of a shorthand for how thick the steel is.
So W10x15 is Wide Flange, 10 inches tall, 15 lbs. per running foot. Anyone who deals in steel will know what this is.
/ Beam size #33
Hit the nail on the head:thumbsup:
ch47dpilot....are you deciding to go with steel?
2021 TRAIL KING 102HGD (A67714)
2021 TRAIL KING...
1998 TRAILMASTER PUP FUEL TRAILER (A67714)
1998 TRAILMASTER...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
2018 Ford F-250 Ext. Cab Pickup Truck (A66736)
2018 Ford F-250...
Kelly-Creswell Model C Walk Behind Paint Striper (A66734)
Kelly-Creswell...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
