BEFCO Inc.
/ BEFCO Inc. #2
Our 6 ft First Choice Finish mower sells for $1395 with solid tires and rear discharge. Considering features and price to Befco, First Choice brand is hard to beat--Ken Sweet
Email sweet@scrtc.com
/ BEFCO Inc. #3
I've used the 5', pull behind finish mower for about 5 years. It's a very good, well made piece of equipment. I would recommend it to anybody. Befco products seem to be at the higher end of the price range but their quality is undeniable. My only complaint after 5 years of constant use is that the middle spindle, because of the design, is a little awkward to grease but that can be said of many 3-spindle mowers. All in all, if a Befco mower is going to be your choice, I don't think you will be disappointed.
/ BEFCO Inc.
I have a 5ft First Choice Finish mower. I would like to get a 6ft mower and would like to go and get it. BEFCO Inc. i can go pick it up. I have look at a lot of Finish mowers and that one looks all most like the first choice. I just do not know any one that had one.
/ BEFCO Inc. #5
I had a Befco before I switched to a MMM. They are excellent quality mowing decks and much of the quality is put into parts you cannot see like the way they have their gears cut. Anyone can build a cheap deck, not everyone can deliver a well engineered deck, Befco makes some of the finest, most innovative finish mowers on the market.
/ BEFCO Inc. #7
I have a 5' Frontier rear discharge RFM made by Befco. It is considered an economy model as the 3pt height is designed for a limited class one with low ground clearance. The four wheels make it handle independent of the tractor. I mow a very rough pasture, as fast as I can, and it does a nice job. I hit a large root which knocked the slack adjuster off. I had to get a socket, open it up and put it back on. It was much easier to work on than a MMM. The blades will need some upkeep but I'm impressed so far with the speed and durability of what I do. The Frontier green matches JD and I'm sure is marked up accordingly.
/ BEFCO Inc. #9
Concur with all the good comments about Befco. I got my my 60" mower as part of a package deal with a used Deere. The mower was used too.
Other then grease, sharpening the blades and replacing the belt, it's done a fine job!
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
2025 SDLANCH SDLC2020 High End Carport (A60352)
2025 SDLANCH...
Four Post 8,000 LB Lift (A62177)
Four Post 8,000 LB...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
2003 Ford Ranger Pickup Truck (A61568)
2003 Ford Ranger...
2014 Ford Escape SUV (A61569)
2014 Ford Escape...
