Bent output shaft on MX5 Cutter
   / Bent output shaft on MX5 Cutter #21
Farley lisa FarleyLisaM@johnDeere.com
Thursday August 18, 2011
Solution number 71454
Why not to buy Jd
Complaint or symptom:
The output shaft on gearbox fails.
The output shaft of the gear box fails prematurely. Customers report that they did not hit any rocks,stumps or obstructions. Multiple failures on a machine may be experienced. The drilled hole for the blade pan retaining bolt can cause weakness in the shaft leading to failure.Solution:
Cutter gearboxes have been revised effective at the following serial numbers:
Mx5. Woomx5x014000
Mx6. W00mx6x029000
Mx7. W00mx7x015000
Mx8. W00mx10x015000
Mx10. W00mx10x014000
For machines prior to the above serial numbers replace the complete gearbox with updated versions as shown on the attached parts listing
Electric Golf Cart (A56859)
Electric Golf Cart...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A58018)
2018 FREIGHTLINER...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
