Bent Pin
/ Bent Pin #1
JDGreenGrass
Veteran Member
Maine
John Deere 770
I knocked my carry all unit into a tree and it bent the framing that houses the attached 3pt. pin.
Bare in mind, this is all new to me....Do I just heat up the powder coated metal with a blow torch and bend it back.??
/ Bent Pin #2
That will mess up the paint a little but it will work, or you can just take a big hammer and "adjust" it, or hit the same tree from the opposite side to bring it back. If it is an angle iron frame or flat plate steel, a large cresent wrench can do wonders in moving things back where they belong.
/ Bent Pin #3
How bent is bent?
Most of my 3pt attachments have pins that have gotten bent for one reason or another, but they still hitch up and work fine.
/ Bent Pin
It's bent directly back and it seems to hang up some when the attachment comes off the hitch.
I need more experience using the 3pt. hitch. Still a rookie with it.
Gonna put a bigger hammer on it this weekend. And, get more practice.:D
/ Bent Pin #5
If it is attached to the typical flat plate or angle iron that I have seen on most carry-alls, you can probably just lay it on the ground and lift it up so the 3 point part that attaches to the tractor is laying on the ground and the cary-all part is pointing up. Take sledge hammer and tonk on the end of the bent pin, it will probably bend right back with little effort.
