best deal ( cheapest price ) on 8/10/12' hog?
   / best deal ( cheapest price ) on 8/10/12' hog? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
best deal ( cheapest price ) on 8/10/12\' hog?
I'm looking to do alot of light pasature cutting.. and want opinions on 8/10/12' rotary mowers.
Light duty is fine.. in fact.. this thing will never see more than high grass tops and some leggy broadleaf weeds.
( no finish mowers though.. just rotary.)
I'm in central florida, for all you other floridians.
I'm trying to find something I can afford.. most all the other stuff in this range is in the 5K$ area..
Soundguy
   / best deal ( cheapest price ) on 8/10/12' hog? #2
Re: best deal ( cheapest price ) on 8/10/12\' hog?
Got a heavy duty 3PH 10.5" Howse for $2200 a few years ago...
I just went and looked at the 10' howse 3pt cutter.. nice looking machine.. and is now about 2400$.. again.. not bad.
Assuming i get the ford 5000.. I'll also be getting that mower.
thanks for the info... I never knew howse had 'big' stuff.
Soundguy
   / best deal ( cheapest price ) on 8/10/12' hog? #4
I have the 10 ft Howse 3 point hitch rotary cutter which I use a JD 5220 (2 wd, 45 hp pto, 53 hp engine, FEL) to power it. This mower weighs about 1800 lbs. The front of the tractor does feel a little light some times when I am moving with the mower raised but when I am cutting it rides on the 2 wheels in the back of the mower and the 3 ph and cuts great. I too am cutting pastures and an old hay field (all total about 150 ac) but I do cut small trees which I would estimate about 2 - 2 1/2" without a problem. It works just fine for me!
Leo
   / best deal ( cheapest price ) on 8/10/12' hog? #5
Soundguy,
I don't know how they compare structurally, but someone should be able to sell you an International Machinery 10' cutter at about the same price you got on the Howse.
Rick
Never heard of them.. least not locally.
Soundguy
   / best deal ( cheapest price ) on 8/10/12' hog? #7
Chris-What kind of transmission does the Ford 5000 have?
Chuck M.
I ended up not getting the ford 5000.. but it had a gear tranny..
Soundguy
   / best deal ( cheapest price ) on 8/10/12' hog? #9
Back in your other thread about 3pt. vs drag, Inspector507 attached a photo of one. They are built in Bethel, Ohio near Cincinnati.
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
TANK MANIFOLD (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
(12) SAFTEY CONES (A58376)
(12) SAFTEY CONES...
40' CONTAINER (A58376)
