Best Mountain Tractor?
   / Best Mountain Tractor? #121
I stand by my previous statement (even if I can't spell /w3tcompact/icons/blush.gif). Here's a little link to illustrate my point: <A target="_blank" HREF=http://www.ask.com/main/metaAnswer.asp?t=m&s=a&en=directhit&o=0&frames=True&url=http%3A%2F%2Fask%2Edirecthit%2Ecom%2Ffcgi%2Dbin%2Fredirurl%2Efcg%3Furl%3Dhttp%3A%2F%2Fhome%2Ea%2Dcity%2Ede%2Fwalter%2Efendt%2Fme%2Fsincostan%5Fe%2Ehtm%26qry%3DCosine%2BSine%2BTangent%26rnk%3D1%26cz%3D87f6eb6fabf13b34%26src%3DDH%5FASK%5FSRCH%26uid%3D0DCE3F7DA326915C3%26sid%3D1CE39F4109F267BC3%26u%3D&ac=62&pt=Sine%2C+cosine+and+tangent+of+an+angle&dm=http%3A%2F%2Fhome%2Ea%2Dcity%2Ede%2Fwalter%2Efendt%2Fme%2Fsincostan%5Fe%2Ehtm&io=0&qid=4D652E3934936249BD804039EF1E3AC5&back=meta%3D1%26site%5Fname%3D%26origin%3D0%26ask%3DCosine%2BSine%2BTangent%26qsource%3D56%26rspick%3Drs&ask=Cosine+Sine+Tangent&dt=020412155208>sine cosine tangent demo</A>
Use your mouse to change the angle. The circle they use in this demonstration is the classic circle with a radius of 1. To get the percent grade, multiply the tangent by 100. You'll also notice that the cosine is the horizontal component of the triangle, the sine is the vertical component of the triangle, and the hypotenuse is always the radius. At 45 degrees, sine and cosine are equal (.707), and the tangent is 1 (x 100 = 100%). As the angle approaches 90 degrees, the tangent approaches infinity.
Veteran Bill, I concur with your degree determination methodology. If I read these cross-currents right, I hear you, Charlie and Egon all saying essentially the same thing with slightly different terms. Clearly degree is different that percent grade. Hundred percent is steep enough for me!
As a mountain man who understands risks, at what angle do you become uncomfortable across hills driving your Kubota B7500, say, dragging either a box scraper or a mower?
   / Best Mountain Tractor? #123
GlueGuy,
Which part of your statement are you standing (probably sitting) by? The part where I am confused or the other part?/w3tcompact/icons/smile.gif My confusion with your post was based on this part <font color=blue>If you operate with a circle with a circle, </font color=blue> I think what you meant was If you consider a unit circle (radius = 1) then.....all the rest follows.
My point was with the original post where the guy drove up the road 1000 feet and then calculated the grade as 10%, because he had an elevation gain of 100 feet. The grade was actually 9.949 %. For the grade to be 10% he would need to travel up the road 1005 feet, with the same elevation gain.
Al
   / Best Mountain Tractor? #124
<font color=blue>at what angle do you become uncomfortable across hills driving your Kubota B7500, say, dragging either a box scraper or a mower?</font color=blue>
I start to pucker up when the meter shows 10 degrees, as holes & mounds makes it jump up and down. If it shows 15 degrees there is no margin; so when that happens I am at a virtual stop, and I inch forward/back & try to get it in a less stressful position. It's gotten over 15 a couple of times, so I know there is some fudge room left, but I'm not inclined to test it.
   / Best Mountain Tractor? #125
Doug: I don't have a meter on my Power Trac 1845, but I've done some rough measurements of slopes I mow. I'm fairly sure I don't reach the pucker factor at 15, but I certainly do at 25-30 degrees. With duals, they say it will go to 40 degrees. Not with me on it. Last weekend, I slid it sideways into a fence, which required some extraction with another vehicle. It was on about a 20-25 degree slope, with the rough cut mower in draft control mode, on wet grass. The slide was slow, and only when I was under power, but I ran out of maneuvering room. The angle of the slope is only one part of the risk analysis. Roughness, obstacles, and traction are also contributers.
I like the Power Trac because it would be very hard to turn it over unless you have a heavy bucket high. It isn't hard, however, to get in trouble sliding. For genuine mountain work, I'd probably load the PT tires, use aggressive ag or R4 tread, and keep reminding myself to slow down.
   / Best Mountain Tractor? #126
Wasabi,
I'm with you. One of the worst headaches I've had in a long time. These guys lost me a long time ago. Who started all of slope, grade, rise, run, hypotinuse, cosine, sin, tangent, stuff anyway? I'm sure that I didn't have anything to do with it./w3tcompact/icons/wink.gif /w3tcompact/icons/grin.gif /w3tcompact/icons/laugh.gif. All that I know is when I am on a steep slope and the rear wheel of my tractor starts to rise, I want to run./w3tcompact/icons/eyes.gif
I was told that my driveway was between 30 and 35deg, % or something. After all of this I don't even know any more. I think that Roy Jackson posted that the best way to check was to use a 100" 2x4. I figured, why not. So when all of these guys get all of this figured out maybe one of them can set me straight and tell me the % grade of my driveway. I used the 100" 2x4, a 4' level and a tape measure. I checked in six places on my driveway. the vertical measurements were between 27" and 31" and averaged 28.7666666" at 100".
All I know is that it is steep and I don't want to try and turn the tractor around on it./w3tcompact/icons/shocked.gif.
<font color=blue>For my Power Trac 1845, with dual tires, 25% to 35% mowing, side hill cutting even, is a piece of cake.</font color=blue> I think that when Charlie slid into that fence, he must have gotten off into the icing... /w3tcompact/icons/wink.gif
Have a good'un guys. This has been real interesting.
   / Best Mountain Tractor? #127
ByuBill
<font color=red>For my Power Trac 1845, with dual tires, 25% to 35% mowing, side hill cutting even, is a piece of cake. I think that when Charlie slid into that fence, he must have gotten off into the icing...</font color=red>
Picking that quote couldn't have proven your point better. 25% to 35% wouldn't have been a problem with dual ags even on the icing. Unfortunately, I was on something over 20 degrees:eek:ver 35%, in the wet, with single turfs.
I guess the degree to percent conversion is what started all this, but whatever the trigonometry, when it's steep, it's easy to get in trouble.
   / Best Mountain Tractor? #128
Charlie,,,,,
<font color=blue>when it's steep, it's easy to get in trouble.</font color=blue>
I couldn't agree with you more... I have had a back wheel off the ground with the fel full more than once/w3tcompact/icons/shocked.gif just going up my drive in the switchback. Not any fun at all.
I have to rely on what I have read about the PT's because I have never seen one in person. I truly think that they are amazing.With the low center of gravity it would be hard to turn one over unless you tried real hard. I just think that some are not thinking about the sliding effect on <font color=blue>a non-ideal surfaced 45% (more or less) slope</font color=blue>. Anytime that any of us are on a slope on anything the law of gravity is just sitting there waiting to take over. So if we all keep this in mind we will have a lot more fun playing (working) on our tractors. With so many first time tractor owners, I would hate to see anyone learn the hard way.
   / Best Mountain Tractor? #129
I spent considerable time on the seat of an Oliver OC-3 crawler. It had the widest track available 68" and was wonderful for sidehilling, until you crawled up on a pole hidden in the leaves. There's pucker power in a sideways slide downhill. ;^)
   / Best Mountain Tractor? #130
That works out to a 28.77% slope (or 16.04°)...close to the limit and plenty of pucker power!!
One of the guys posted about sliding sideways on wet grass...
Boy, I was going across a slope (maybe 10°...or less) in a 1972 GMC 4x4 pickup (real macho truck...who needs power steering and any other amenities?!). Well, wet grass...every foot forward I went down slope a foot...until I hit a fence at the bottom. Had a heck of a time getting that truck out of there...
Yepper, wet grass is slicker then greased owl ****...
MISC WRENCHES (A53843)
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
11 SERVICE BODY BED (A53843)
11 SERVICE BODY...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2008 New Holland L175 (A47477)
2008 New Holland...
