Best Oil for older John Deere
   / Best Oil for older John Deere #1
Magruder
Michigan
John Deere 790
I have an AR that I need to change oil on for the first time. What is the best oil for an older tractor like this?
   / Best Oil for older John Deere #2
Do you have a picture of that AR??
murph
   / Best Oil for older John Deere #3
When it comes to antique iron.. keep in mind that -any- oil you can buy right now.. will be superior to what that thing probably ran on new.. and that includes brigs and stratton 30w non-det, and 'jiffy-store' 84 cents a quart type stuff.
On my B I changed the oil about 3 times the first week I had it to get it completely flushed out. i used supertech oil from wallmart.
Soundguy
   / Best Oil for older John Deere #5
I dont know if this applies to you, but in my old '52 dodge M43 I use a non-detergent oil.
anything that is real old you "may" want to keep using a non-detergent. If you do not there is a possibility that the newer detergent type oils will loosen up some sludge that may become a problem.
just something to think about.
   / Best Oil for older John Deere #6
While that's true.. that a swap from ND to D oil may cause sludge movement, you can take steps to 'help' the process along. Like go with a 50/50 mix of d/nd oil for an oil change.. use a lower hour interval.. use an intermediate filter change. or even do successive oil changes say 10 hours apart.. or a couple weeks apart.. with a filter change inbetween.
Soundguy
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
1999 FORD F550 BOX TRUCK (A54313)
1999 FORD F550 BOX...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
