Best place to pick up a PTO driveline shaft?
   / Best place to pick up a PTO driveline shaft? #1
DanMc77
JD 4600, JD 2210, JD 332
Just acquired a like-new LandPride SB1051 3 point rear snowblower. The PTO shaft that came with it is too short. Where is the best place to get a cost-effective replacement shaft??
It must have a shear pin or slip clutch since this is going on my 2210. I'm measuring 26" between the end of the two splined shafts.
   / Best place to pick up a PTO driveline shaft? #2
Tractor supply or Agri supply? I've found Agrisupply has better prices, but not sure how shipping would factor in GA to NH. Both do online orders
   / Best place to pick up a PTO driveline shaft? #3
A&I. Your local tractor dealer is probably an A&I dealer.
Don't buy anything less than a Series IV shaft and make sure it has a shearbolt flange arrangement comparable to the OEM shaft.
   / Best place to pick up a PTO driveline shaft? #5
Question: I need to buy a new driveshaft to fit my new larger tractor. What is the correct way to size a driveshaft to a tractor/implement combination?
I figured out that I could purchase a new longer series 4 internal trilobe tube from AgriSupply. Popped out the roll pin that holds the inner tube into the U joint. Took apart the U-joint and now have to get the tube pressed out.
Edit: I posted this before I noticed the suggestions above to do just this! Thanks to those guys with that suggestion!!!!
Edit again: I was able to bang out the tube with a BFH and a deep socket as a punch.
@jyoutz : I'm learning this myself. You need to measure the size of the sliding tubes that form the shaft. That will tell you what series this is. I just know that inner sliding tube of the series 4, which I have, has an OD of 36 mm.
This is from the AgriSupply site:
  • Width: 36 mm or 1-27/64 in.
  • Thickness: 4.5 mm
Here's the prize. I'm loving the way this thing is built. I considered shortening the 3 PT mount, but chose against modifying it.
The PTO shaft is indeed dangerously short!
   / Best place to pick up a PTO driveline shaft? #9
  • Thickness: 4.5 mm
My driveline is old and I just plan to replace it and slip clutch, so I don’t need to match anything. I’m just wondering how to measure for length and overlap of the new driveline.
   / Best place to pick up a PTO driveline shaft? #10
Go to your tractor dealer, they will match and you can buy replacement tubes for your PTO pretty cheap. Cheaper than buying a whole new PTO.
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54757)
(2) LITHONIA...
2013 BMW 528I (A47477)
2013 Ford Escape SUV (A55758)
2013 Ford Escape...
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
2012 PETERBILT 365 (A55745)
2012 PETERBILT 365...
