best portable boombox or radio to buy?
   / best portable boombox or radio to buy?
ok what is a good radio to buy for a tractor, a normal car fm radio would work right?
i need 3 of them, only interested in the am/fm radio, nothing else, something i can install myself thats easy to replace my am radio in tractor, and cheap but will work as long as any radio for a long time
also would like a sirius adaptor fm, i heard they elimate any static, is there a place on ebay where i can buy all this stuff right away instead of ordering from several places
   / best portable boombox or radio to buy? #13
yeS a normal radio would work in the tractor. Only problem would be finding a way to mount it so it didnt get wet. Do you have a cab or a canopy? Thats one way where a jobsite radio would work, not only are they water resistant (most of them) but you can take it in when it rains or you store the tractor.
I dont think you can even buy a AM/FM only radio anymore, only ones with a cd player. Check walmart or similar retailers.
The Fm modulators are pretty good.
THere are a couple different kinds, one is hard wired the other is wireless.
Wireless would be more convienant as you can take it from vehicle to vehicle. It would also be cheaper because you'd require a hard wire adapter for each vehicle.
You would need a 12V cig lighter outlet to power the wireless.
Heres a link to wireless Universal Sirius XM Wireless FM Transmitter Modulator - eBay (item 190310067997 end time May-31-09 20:06:22 PDT)
Another option would be headphones, if your sirius is compatible. Personally i dont like headphones because you cant hear whats going on around you, and i think they're illegal to wear in cars.
its a cab, radio on the roof of it, if the wired radio plugs into the cigar outlet, how will i power the sirius radio, i already have the sirius radio powered by it
what is fm modulator?
dont want headphones
   / best portable boombox or radio to buy? #15
YOur tractor has a radio and speakers now? If so just remove the old radio and install a new AM/ FM. Your radio should be receiving its power from the tractors wiring harness.
The cig plug is just there to power the transmitter that the modulator uses to send the music from your sirius to the tractor radio. If you look at the link i posted youll see what i mean. The modulator i linked to will also charge your sirius at the same time so you wont need the 12v cord that came with your sirius anymore.
A FM modulator, is a device that takes the output of a music player, like a sirius, and changes it into FM radio signals so that you can play music over the stereo thats in your vehicle. Think of it as your own personal miniture FM radio station.
the link you posted for ebay, this might work better for me seeing how i have SEVERAL trucks and tractors i work with, instead of installing a fm radio in everyone of them i could just use this right?
also which one of them are the best, is the one with the link you posted, is is the best of its kind, cant seem to find any reviews of it
also i heard a fm direct adaptor clears any static, getting that any good?
also just to be clear, is this thing really a fm radio, will it plug into my sirius and give it power and then plug other end to cigar outlet, how will it run to my speakers in truck?
remember i only have a AM ONLY RADIO, that and my sirius radio, will this thing work me without anything else, i dont need a fm radio installed already?
also what if im not near anything, does this fm trantsmitter need to be within range of a truck fm radio somewhere? how does it exactly work, i know nothing about transmitters
   / best portable boombox or radio to buy? #19
To work with the WIRELESS system you need a FM radio. THis means that youll have to remove the am radio from your tractor and buy a new AM/ FM.
Youll need a FM radio in EVERY vehicle that you want to have Sirius in.
A modulator is NOT a FM radio. Its a FM TRANSMITTER...It doesnt receive Fm only transmits.
For multiple vehicles , like you have, a wireless system is best because you can move it from vehicle to vehicle, but each vehicle needs a FM capable radio in it.
Even the hard wired ones require a radio capable of receiving FM.
As i do not have a Sirrius radio, I do not have any hands on with the particular model i linked to on ebay, however they all work basically the same way. THe one i use with my ipod is made by Belkin.
THe modulator is basically just a FM transmitter. It broadcasts to your radio on the FM band. Its range is only around 10ft. so youll need to have it with you in whatever vehicle your driving.
Your radio, in the vehicle is what sends the music down to your speakers. Just like it always has done, nothing changes except that its on FM instead of AM, and the source is the Sirius, instead of the radio station in your town.
so why buy this, when i just buy the fm radio and thats it, what does this thing serve as its purpose?
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
Honda EM3500S Generator (A55851)
Honda EM3500S...
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
