Best Steel Finish
   / Best Steel Finish #11
they way I do a tractor is to remove paint and get down to bare metal.. remove rust, degrease and clean.. apply a primer, then a hardened enamil.
paint don't rust. :)
   / Best Steel Finish #13
I sandblasted my snow blower and immediately primed it with TREMCLAD primer.
Next day I sprayed it with tremclad enamal, that was about 4 years ago.
Even today the Tremclad is holding up fine.
But then I think sandblasting is just about the ultimate metal preparation as it gives that 'toothy' base for the prime to adhere to, and naturally enamels really need a prime base.
   / Best Steel Finish #14
i built my equipment trailer about 12 years ago. it was all new steel, but even still there was rust from outdoor storage at the steel yard. i wire wheeled it and then wiped it down with cheap paint thinner. paint was a brush coat of clean metal primer and a topcoat of rustoleum sunburst yellow - two coats on the very top surfaces. it has held up perfectly and the only rust showing is where i've scraped the paint off. it's been outdoors the entire life. certainly not as pretty as a nice sprayed finish, but for something that has to earn its living through function as opposed to just looking good, i'm content with it.
i actually am not impressed with powder coating on equipment that gets used. if you buy new and trade stuff in every few years it's fine, but if you have it long term around here it actually gets far rustier than paint. the powder coating is so tough that it remains intact when moisture gets behind it through a scratch or improper metal preparation. the rust then spreads and grows behind the powder coating, rather than just come to the surface in one spot as it often does with paint.
   / Best Steel Finish
I haven't had your good results lostcause! I took my time refinishing an equipment trailer quite a few years back- and used the same products, only I was very disappointed in how it looked within two years time. And it took a lot of effort to get the surface ready for paint- so I was very reluctant to try it again.
I generally agree with your assessment of powdercoating. I was mainly thinking of that for a brush guard I'm currently building for my truck.
   / Best Steel Finish #16
If you'll sandblast the metal, then treat it with Ospho, you're done. (but it's expensive)
   / Best Steel Finish
Thanks for the advice TBN folks. So far I've seen a few products recommended that I haven't even heard of before- that's exactly why I posted
   / Best Steel Finish #18
I would stay away from any miracle products. There are a lot of gimmics out there which are marketed aggressively to do it yourselfers. Do your own researsh and you will find that epoxy primer is the leading technology at this time. You might find some dinosaurs still using acid etch, but you wont find any professionals using rustolium, or any of the various miracle products.
Blast your brush guard until it is gray metal.
Clean it with a good automtive grade wax and grease remover.
Spray 2 coats of epoxy primer
Top coat with single stage urethane paint (for best results).
You could use tractor enamel, or whatever as a top coat, but it will chalk out eventually. It depends what you are going for. The epoxy will protect it against rust 100%, even if it is not top coated at all. I good urethane paint will have excellent scratch resistance and uv hold out.
   / Best Steel Finish #19
My thing for steel, clean,rusty whatever is a 50 50 mix of terp and linseed oil slopped on with a rag.
Add a dollop of black Rustoleum if you want color.
For bush hogs plows blades and stuff it's the Schmidt.
   / Best Steel Finish #20
I am one of the dinasaurs that still use etching primer. I only use it on equiptment. If you have ever sand blasted any thing that was primed with etching primer you will be impressed. It is nasty to spray and an ugly green but it holds up better than anything I have used. 5-Star Direct To Metal Self-Etching Primer w/ Reducer: Automotive Paint, Auto Paint, Car Paint This is what I use.
Bill
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
KENWORTH VIN - (A50323)
KENWORTH VIN -...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
