TRR
I've had the best results using this:
Sandblast to bare metal
Allow to get a flash coating of rust
Apply OSPHO - (converts iron oxide to iron phosphate which acts as a primer)
Apply a zinc spray coat
Top coat
I did an experiment with this in Florida many years ago. 3 samples of 2 each methods. The method above was one, the second method left out the OSPHO. The method without the OSPHO lasted 3 years before rust started showing thru. The one with OSPHO was 7 years, even then the pressure treated post it was mounted to had to be replaced before the steel sample had to be refinished.
Top coat
