Best Tractor Battery / charging system issues ?
   / Best Tractor Battery / charging system issues ? #1
John_Mc
Elite Member
Monkton, Vermont
NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I've had a problem with my NH TC33D tractor almost since the day I bought it (it's a 2001, if I recall correctly). The battery terminals - mainly the positive one - corrode up constantly. I've tried all sorts of sprays, treated felt washers, greases, etc. nothing seems to make much difference. I forget if it's two or three times now that it has corroded the lug that goes on the positive battery terminal almost down to nothing: what used to be a solid chunk of metal ends up looking about the thickness of a hose clamp. If I have to, I can live with getting only 5 years life out of a battery (though this is the only vehicle I've owned, including several tractors that I can't get more battery life out of). I do mind getting only 5 or 6 years out of my battery cable.
I suspect two things:
  1. The heat from being right near the radiator is causing problems (and possibly vibration from engine or use on rough terrain)?
  2. The electrical system is overcharging the battery.
Does anyone have suggestions on this? The first time it happened, I asked the dealer to check over the charging system, and they said it was fine. I don't know how thoroughly they checked it. They may have just looked to see that it's charging and left it at that, rather than seeing if it's putting out the right voltage. I've asked them to verify proper operation and check charging voltage this time.
Is there a better battery to use than what the dealer is selling (just a regular variety lead-acid battery). Would an AGM battery be better suited to the heat/vibration? Any recommendations on brands? I've heard good things about Optima batteries, but don't know if they are suited to tractor applications, and if so, which type. I do know that AGM batteries prefer a little different charging and float voltage than flooded lead-acid batteries. If I make the swap, do I need to change anything in the charging system, of is this likely to be "close enough"?
   / Best Tractor Battery / charging system issues ? #2
I just replied to your other thread. You need to determine what your charging system is putting out. You should have 14.25- 4.5 Volts returning to your battery, regardless of lead acid or AGM battery use.
Before changing anything supply us with what your alternator is outputting.
I suspect your real issue is one of bad grounding on the tractor.
Look at the places where grounds are: chassis of tractor where the negative cable connects, etc. Look for corrosion there, and make sure there is no corrosion in the actual cable under the plastic jacket near where it connects to the frame/chassis.
Report back outcomes before doing any battery replacement or other parts swaps.
Why now? 15 years of this going on?:confused3:
   / Best Tractor Battery / charging system issues ? #3
I would have wondered if the OEM battery wasn't sealed properly at the terminal. But you are on your third or so battery. I have used the felt washers with good results. A friend is always giving me cans of the spray stuff from work, but it's messy and attracts dirt.
I have had many batteries in the same heat/vibration environments without this issue. Periodic mainenance and cleaning is a MUST however. Install and forget a battery and I can guarantee, something BAD will happen! I had a corrosion bridge form on our JD to a hold down bracket, effectively slowly draining the battery. But that was also an old battery. Then of course, your charging system puts a wack of current into that discharged battery, creating even more gassing.
Get rid of old batteries! For the number of starts you get out of a battery, they are not expensive.
If your battery was overcharging, I think you would get very short life out of it.
A mystery!
   / Best Tractor Battery / charging system issues ? #4
I have one terminal on the positive post on one of my golf cart batteries that eats up the terminal lug for some reason. None of the others corrode up like that one, but I have no idea why.
None of my vehicle /tractor batteries eat the terminal like you describe. Coyote Machine might be on to something with the bad ground connection to the frame. My LS 6 year old battery was dead from setting all winter but after fully charging it up, it has been good to go for about 3 weeks of setting and no problem. There is absolutely no corrosion on any of the terminals on it or my 2009 Kubota battery. The only maintenance I have given either of them is a hosing off of the dust occasionally. Both are maintenance free type so no water to add.
   / Best Tractor Battery / charging system issues ? #5
^ What he said. ^
First check all the terminals and replace, clean as necessary. You need to do something to neutralize all that corrosion then protect the surfaces that you cleaned up. Paint for clamp and such and one of the protective sprays or greases for the terminals themselves.
Put a know to be good voltmeter on it with the tractor running to see how much the voltage the regulator/alternator is putting out. I has to be more than the battery voltage in order to charge the battery but not so much as to boil the electrolyte. At idle, most charging systems will produce 13.8 to 14.3 volts with no lights or accessories on (although some may charge at a slightly higher voltage depending on temperature, engine RPM, type of battery, and the battery's state of charge). Anything over 15V is likely to boil the battery dry.
After you get everything working as it should be, unless you are running the tractor frequently as in every day or two I suggest you get a maintenance charger and connect it to the battery while the tractor is parked. I have one installed next to the battery and always connected to the battery terminals. When I park the tractor I just plug it into wall current with an extension cord via the dangle plug.
Maintenance chargers are low current so they don't cost much ($20-$30), they are made to maintain battery charge not recharge a dead battery. However the one you get should cycle on and off automatically with the voltage so as not to overcharge and damage the battery.
When you have to replace the battery, investigate the AGM types that are maintenance free and are superior to wet cell batteries for tractors for a number of reasons, however they do cost more as nothing is free. Still even with those you should still use a maintenance charger if the tractor is left parked for long periods.
   / Best Tractor Battery / charging system issues ? #6
Lots of good suggestions. I will add that some machines really drop off the charging voltage at idle, so when you put a meter on it, raise the rpms a little.
Once you confirm charging voltage, ground, and clean up the connections (remove and actually clean up the connecting surfaces), consider a sealed battery like the Optima red or yellow top.
I have optima batteries in all sorts of stuff, and highly recommend them.
   / Best Tractor Battery / charging system issues ? #7
I have replaced my OEM battery with an Odyssey. Its AGM and holds a fantastic charge. I've never had problems with either pole corroding. I do hose the battery down every spring, remove both leads, clean the posts & lead ends, relube with a spray product and have felt pads under each post. I keep the battery connected to a maintenance charger all the time.
Its very likely that corrosion of one or both terminals is related to lack of good grounding of the tractor.
Thanks guys. The tractor is at the dealer's now, getting hydraulics plumbed for a log grapple to swap in for the loader bucket. So I can't check voltages right now. I did check when the new cable end and new battery were installed years ago. Charging voltage seemed normal (going from memory, but it had to have been slightly over 14 V, or I would have taken steps to correct it). I have not monitored voltages over the years since then - should have, but didn't.
Corrosion has been an issue on that battery post almost since the tractor was new. The first time this happened, I figured I just had a bad battery or bad luck. Had the dealer check it over when it was in for other service - ended up replacing the whole positive cable, since it ended up too short to reach when the damaged part was removed. The damage this time was hidden under the rubber boot over the battery connection. I had noticed some corrosion some time ago, and cleaned things up. Just let it go to long this time before checking again. The majority of the damage probably happened in the last 1.5 years or so.
I have not checked the ground connections. I'll do so when I get it back.
The tractor is kept on a maintenance charger when it will not be used for an extended period. I use BatteryMinder chargers - after researching for my aircraft battery (costs close to $400 to replace). I settled on that brand because of great reviews and design features (temperature compensated charging and float voltages, desulphation feature, 5 stage charger). Results have been excellent. I own four of these chargers in various models. So I'm confident that the problem is not coming from allowing the battery to discharge too much, or from over charging (at least not overcharging from the battery maintainer).
   / Best Tractor Battery / charging system issues ? #9
I agree with almost all of what has been suggested, especially Oosik's reference to grounding connections. I also recall being advised some years ago that acid buildup on one terminal or the other was due to charging voltage being a little high or low ... the problem is I cannot remember - or find - which one affected which terminal. :confused2: Best cleaned off with boiling water and a brush, then coated with appropriate terminal spraypaint, or several light coats of spray-grease - the aim is to keep oxygen off the exposed metallic areas of the terminals and cables.
On the subject of the best battery - from 37 years in the auto trade, plus growing up surrounded by machinery: Several brands used to be very good quality and extremely reliable, but nowadays are rubbish. Having said that ..... all brands will fail at some stage - generally when it's most inconvenient, but nothingnlasts forever. Absolutely NOTHING is better than a VARTA battery. :) They should be available in the USA and various other countries, as I see them in almost every make of European vehicle at work. They are frequently renewed as a precautionary measure at 6-7 years old, but generally they are still quite Ok. I have put one when a replacement has been required in each of our tractors, four cars, ride-on mower, jump-start battery, electric gate and anywhere else needed. All three tractor batteries are well over ten years old :eek: and yet still quite happily start a 3cyl Perkins or 4cyl Vanguard diesel, even after standing unused for several weeks. :thumbsup:
   / Best Tractor Battery / charging system issues ? #10
The tractor is kept on a maintenance charger when it will not be used for an extended period. I use BatteryMinder chargers - after researching for my aircraft battery (costs close to $400 to replace). I settled on that brand because of great reviews and design features (temperature compensated charging and float voltages, desulphation feature, 5 stage charger). Results have been excellent. I own for of these charges in various models. So I'm confident that the problem is not coming from allowing the battery to discharge too much, or from over charging (at least not overcharging from the battery maintainer).
I've had corrosion issues on some in the past, but I started using a BatteryMinder and have had no issues since. I do not leave mine connected all the time, but connect to each battery for a day or so every couple weeks when they are not frequently in use. Are you connecting your BatteryMinder directly to the battery, or to remote terminals or frame?
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
