Best way to clean rust from my fuel tank
   / Best way to clean rust from my fuel tank #21
Actually what works quite well is to use molasses mixed 8 -10 to one with water. Just submerge and leave it sit for about 2 weeks. With a fuel tank you probably should drain and re submerge a few times just to circulate the mix through the tank. I used this on some rusty tractor sheet metal that I had and I was very impressed. Apparently it works by chelation.
   / Best way to clean rust from my fuel tank #22
I had an issue with a tank an old CJ5 and I bought a product from Napa Auto Parts to seal it. First, I flushed it out several times with water. You just keep washing it until it comes out clean. Then you let it dry. Then you pour in their solution and slosh it all around so the entire inside of the tank is coated. Let it dry and install it again. Solved my issue for a fair price.
   / Best way to clean rust from my fuel tank #23
In the past I have drained the fuel tank and let it sit dry. Then used a shop vac and suck out anything left in the tank. It worked quite well.
Yup, what I did was let it dry, used a long fine steel tip on my air compressor to blow air in, and wedge in the tip of the vacuum cleaner. Use a rag to seal up the opening as much as possible. Rinse and repeat with gas. Cleaned up the tank nicely.
   / Best way to clean rust from my fuel tank #24
At first I thought you were having trouble due to drinking Jack Daniels instead of something good like Crown royal Northern Harvest .
   / Best way to clean rust from my fuel tank #25
I never did this myself, but I heard coke (the drink) will eat rust pretty good.
   / Best way to clean rust from my fuel tank #27
I recently got a gas generator with a fuel tank so rusty it clogged the 1/4in pet cock in the bottom of the tank even after a drain and shake with a chain in it.
I ended up using electrolysis. Basicly pool PH, a battery charger and a piece of steel. The amount of goop that came out was amazing and I didn't have any real bad chemicals to get rid of.
   / Best way to clean rust from my fuel tank #28
How does that work?
   / Best way to clean rust from my fuel tank #29
Google it. Basicly All the rust attacks the steel rod you stick in the tank. Worked real well, and next to no labor. You really don't even need to remove the tank.
   / Best way to clean rust from my fuel tank #30
I like that. :thumbsup:
1999 Yamaha G16A Utility Cart (A52377)
1999 Yamaha G16A...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
VOLVO MOTOR WITH CHASSIS (INOPERABLE) (A53843)
VOLVO MOTOR WITH...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
SEMI AUTOMATIC QUICK CHANGER ATTACHMENT FOR MINI EXCAVATOR (A53843)
SEMI AUTOMATIC...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
