best way to move big-ish rocks?
   / best way to move big-ish rocks? #31
Rolling works pretty well, slow but sure,. also can push each end of a rock to do the final setting of them where you want them. Lift a little and push one end, and then move and lift and push the other end. You can "scoot" a pretty big rock.. I once rolled a large limestone with a little B7500, I bet it weighed more than the tractor. I moved it about 40 foot, took forever, and it was slightly downhill, but I "got-er-done". We have a lot of rocks.. not much dirt, but a lotta rocks.
James K0UA
   / best way to move big-ish rocks? #32
Had the same issue on my place - suitcase-sized rocks lying around or sticking up out of the ground. What I did was put the FEL flat on the ground right next to the rock, maybe even touching it.
Then, get a digging bar and stick one end under the side or end of the rock and just work it into the FEL. If it's a real monster, you might have to work it in an inch at a time. Works fine. Good exercise, too....:cool:
If the rock's stuck in the ground, use the rippers on your box blade to snag it and move it to the surface.
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
30ft Highway Trailer Co. Lowboy (A55315)
30ft Highway...
2025 SGB20 20in Hydraulic Grapple Stump Bucket (A55851)
2025 SGB20 20in...
2021 Billy Goat F902H Walk-Behind Debris Blower (A55851)
2021 Billy Goat...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
