best way to move big-ish rocks?
   / best way to move big-ish rocks? #21
Really? I'm dealing with granite here... and I want to move it along some back roads, which technically aren't public, but I'd rather not crush passing cars with out-of-control Indiana-Jones-style rolling stones...
They don't roll out of control because they're not normally perfectly round. Doesn't matter the shape. Just roll it over one turn at a time. I've moved extremely heavy rocks this way - uphill and downhill.
If you've got to go over roads, roll it up the ramps onto a landscape or equipment trailer, chain it down and go to it.
Rolling is the safest. Lifting, if possible, is dangerous. Skidding can be too. The rock can slide where you don't want it. One roll at a time can be very well controlled. You can roll way more than you can lift or skid. I built a 100 foot long boulder retaining wall about 6-8 feet high with my little B2630 - I've moved a lot of rock.
   / best way to move big-ish rocks? #22
Ive moved way bigger rocks than that with my b2630. Talking like 5-6 foot diameter. Just use the loader to roll the rock along to where you want it. Rather easy actually.
I have a rock about that size that I want to move. Thought it would be too big to drag, for sure too big to lift. Don't know why I never thought of rolling it. I'll probably still wait for the ground to freeze a little bit so it doesn't sink into a soft spot before I get it where I want it. The ground is pretty solid most of the way. I'll have to give it a try in the next few days.
   / best way to move big-ish rocks? #23
Roll them on a hood off a truck, chain to drawbar and drag 'em.
seymojo, I like it for the smaller ones, My dad decided to buy us kids a snow mobile back in 1969, cuz I was giving my siblings a snow sled ride using a truck hood and a new jd 4020, a $10.000. dollor tractor running around in the hay field, .LOLOLOLOL,.HEHEHE,...:D:laughing::D:laughing:.Eric
   / best way to move big-ish rocks? #24
I use my tree spade bucket, the longer reach and curved sides work wonders for moving boulders.
Are u talkin about using a hydraulic tree transplanter with retracting spades??
   / best way to move big-ish rocks? #26
YUP,..What he said,..Eric
   / best way to move big-ish rocks? #27
You might need front chains, CUZ you might have to wait till frozen ground start lookin around for a cheap set,...Eric
   / best way to move big-ish rocks? #28
No I think he's talking about a pointed bucket for the loader. I have one. It's basically like a giant pointed shovel. Picks up rocks easy.
   / best way to move big-ish rocks? #29
Or if you really want to help the economy out of recession and spend the bucks you can get a grapple.
   / best way to move big-ish rocks? #30
Boulder sling, $10 in chain
The paint is to eliminate confusion when tangled.
Hey that's a great idea! I have a white quartz rock in the woods that I would love to get to the top of the driveway. I think I could to it with this. Thanks!
   / best way to move big-ish rocks? #31
Rolling works pretty well, slow but sure,. also can push each end of a rock to do the final setting of them where you want them. Lift a little and push one end, and then move and lift and push the other end. You can "scoot" a pretty big rock.. I once rolled a large limestone with a little B7500, I bet it weighed more than the tractor. I moved it about 40 foot, took forever, and it was slightly downhill, but I "got-er-done". We have a lot of rocks.. not much dirt, but a lotta rocks.
James K0UA
   / best way to move big-ish rocks? #32
Had the same issue on my place - suitcase-sized rocks lying around or sticking up out of the ground. What I did was put the FEL flat on the ground right next to the rock, maybe even touching it.
Then, get a digging bar and stick one end under the side or end of the rock and just work it into the FEL. If it's a real monster, you might have to work it in an inch at a time. Works fine. Good exercise, too....:cool:
If the rock's stuck in the ground, use the rippers on your box blade to snag it and move it to the surface.
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
GUN BOX FOR TRUCK BED (A60432)
GUN BOX FOR TRUCK...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
Kubota M5-111 (A53317)
