Best way to protect from weld spatter?
   / Best way to protect from weld spatter?
Years ago I was given a lot of asbestos welding blankets, I use them to protect everything. I doubt you can buy asbestos, (new anyway) but maybe theses would work too.
6 Ft x 8 Ft Fiberglass Welding Blanket
I actually do have a sheet of asbestos that I have squirreled away. I use it occasionally when I sweat pipes near wood. It is getting kind of crumbly, though.
   / Best way to protect from weld spatter? #12
I use an anti-spatter spray , duct tape or a welding blanket whatever i can get my hands on
   / Best way to protect from weld spatter? #13
Nozzle/Tip dip.
   / Best way to protect from weld spatter? #14
I use the anti-splatter nozzle spray too. (Black Magic).
Since switching to flux core wire, I have found splatter is definitely a draw back to using it.
   / Best way to protect from weld spatter? #15
koritina said:
Nozzle/Tip dip.
Nozzle gel for a mig gun works great. Smear it on with your fingers. Reasonably cheap as well.
   / Best way to protect from weld spatter? #16
When I was a pup and just learning about stick welders an old man suggested to me that if I would turn my amps down to where they should be most of my spatter problems would go away. He was correct but on surfaces like the OP has we still need some protection sometimes.
   / Best way to protect from weld spatter? #17
Welding tips and tricks says Pam spray works great as a nozzle spatter deterrent.
OP here.
Thanks for all the suggestions. I welded it today. I put some woven asbestos cloth I have had forever on the critical surface next to the weld, held with a hose clamp, then draped a wet rag over the rest. It worked just fine.
   / Best way to protect from weld spatter? #19
When I took a stick welding course, my instructor said to keep the arc short. I still have a tendency to carry a long arc and I get lots of splatter. It's not that much of a factor for what I do most of the time. I've used wet rags but there were some other good ideas( foil and duct tape) presented here.
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2014 Cummins ISL 320HP 8.9L 6-Cylinder Turbo Diesel Engine (A55852)
2014 Cummins ISL...
White Metal Roof Panels (A55758)
White Metal Roof...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
