Best way to protect from weld spatter?
   / Best way to protect from weld spatter?
Years ago I was given a lot of asbestos welding blankets, I use them to protect everything. I doubt you can buy asbestos, (new anyway) but maybe theses would work too.
6 Ft x 8 Ft Fiberglass Welding Blanket
I actually do have a sheet of asbestos that I have squirreled away. I use it occasionally when I sweat pipes near wood. It is getting kind of crumbly, though.
   / Best way to protect from weld spatter? #12
I use an anti-spatter spray , duct tape or a welding blanket whatever i can get my hands on
   / Best way to protect from weld spatter? #13
Nozzle/Tip dip.
   / Best way to protect from weld spatter? #14
I use the anti-splatter nozzle spray too. (Black Magic).
Since switching to flux core wire, I have found splatter is definitely a draw back to using it.
   / Best way to protect from weld spatter? #15
koritina said:
Nozzle/Tip dip.
Nozzle gel for a mig gun works great. Smear it on with your fingers. Reasonably cheap as well.
   / Best way to protect from weld spatter? #16
When I was a pup and just learning about stick welders an old man suggested to me that if I would turn my amps down to where they should be most of my spatter problems would go away. He was correct but on surfaces like the OP has we still need some protection sometimes.
   / Best way to protect from weld spatter? #17
Welding tips and tricks says Pam spray works great as a nozzle spatter deterrent.
OP here.
Thanks for all the suggestions. I welded it today. I put some woven asbestos cloth I have had forever on the critical surface next to the weld, held with a hose clamp, then draped a wet rag over the rest. It worked just fine.
   / Best way to protect from weld spatter? #19
When I took a stick welding course, my instructor said to keep the arc short. I still have a tendency to carry a long arc and I get lots of splatter. It's not that much of a factor for what I do most of the time. I've used wet rags but there were some other good ideas( foil and duct tape) presented here.
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A55314)
2023 Kubota Z412KW...
