BH 75 Hoe on a 2800/3400?
   / BH 75 Hoe on a 2800/3400?
Thanks Wushaw. From the looks of the pic, I am going to run into some trouble hooking up my tiller and possibly some other things. The two hook up pins on my tiller are fairly close together. It looks like the stabilizers will hit the subframe if you had to move yours lower hitch arms close together.
   / BH 75 Hoe on a 2800/3400? #13
You won't have any trouble, I have not had any problems with any of my implements causing any interference troubles.
   / BH 75 Hoe on a 2800/3400? #14
What a wonderful tractor backhoe combination-- . Congratulations.
Since no one mentioned it I will add to make sure you leave the bucket on if the backhoe is on. The weight is needed.
Could someone post a pic of their BH75 mounted on a 2800/3400? I can't find any photos of the hoe anywhere on this site. I found a few with bent dippers, and a few on smaller machines and that is all.
Also, is it possible to operater the hoe with the ROPS folded in the down position on the 2800/3400? Will there be clearance issues with the seat? Thanks, I will quit bothering y'all now. :)
   / BH 75 Hoe on a 2800/3400? #16
The Rops would be in the way of mounting/dismounting the hoe operator seat.
I only have picts of mine sitting on the stand I built, I never took any operation picts, it wasn't like I didn't have an opportunity with the time the hoe has been on the tractor.
   / BH 75 Hoe on a 2800/3400? #17
There is at least one picture of a BH75 mounted on an L2800 at Kubota's web site in the L gallery.
Stopped by the dealers today to sign off on the hoe. I probably won't be able to get it installed till next week - the spring mowing rush is on an they are selling tractors about as fast as they can get them put together and delivered. I thought about doing the install myself, but only after I had signed off on the price that included the install. I guess I will have to be patient.
I told my wife that we better go get a 50lb bag of grass seed, cause I'm going to have holes dug everywhere.:)
   / BH 75 Hoe on a 2800/3400? #19
That you will:)
I seen one of the Google Earth pictures of my place once and I colud see many spots where I removed stumps.
   / BH 75 Hoe on a 2800/3400? #20
I've got a L2800 with the BH75A backhoe. I'll try to get some pictures in the next day or two and post them.
New Long Forks (A53002)
New Long Forks...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
