BH 92 Problems
   / BH 92 Problems #11
Better to have a snug fit, one might think. It might free up with some use, although I have one loader pin that needs a few taps to go in, even now after 8 years.
True!
   / BH 92 Problems #12
I have the bh65 on my 2620 and the first few times I detached it I had to really work the pins. Now that I have a few hours on it and have taken it on/off many times it is a snap. Some folks have ground the pins down a bit so that they fit in more easily.
I made a dolly out of some old pine and wheels and that really helps to align the pins so that installation is but a minute or so.....good luck on getting your bh fixed up.
   / BH 92 Problems #13
I know this isn't the issue with the OP's machine, but both of my B series had at least one of the 2 pins being a bit too snug and very difficult to install/remove. Taking the paint off the inside of the hole helped, and sometimes I have to install one pin, and then either try to raise the hoe higher or drop it just a tad to get the other side in. Have to figure the jigs get a bit out of whack every so often when they're building the frames and the reinforcements are welded on just a bit off from frame to frame.
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Sedan (A59231)
Sedan (A59231)
golf cart (A56859)
golf cart (A56859)
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56436)
Bulk Lot of NEW...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
