bh as weight for winter snow removal
   / bh as weight for winter snow removal #1
DannyD
Indiana
BX 23
is this safe guys? As you know I have a bx 23, with all the trimmin's, I am wondering if I should put the hoe on for the winter as a counterweight to the fel. If in fact we do have a heavier winter than last, may need more than what I did with the 2200 last year.
thanks
Danny
   / bh as weight for winter snow removal #2
WELL IT WILL ADD WEIGHT! /forums/images/graemlins/grin.gif but might be a tad unwieldy(?) if you have to work in close quarters.
   / bh as weight for winter snow removal #3
Safe, yes and more then enought weight. As Frank said it can be a ______ in tight spaces.
I did not use any weight last year and we had a few stores with over 18" and worked perfect on my Bx22. Just kept the FEL close to ground and used 4x4 at times. But my yard is as flat as a pool table.
I might make a blast box about of the (4) 5-gallon buckets I have full of lead! /forums/images/graemlins/smile.gif If I need a winter project.
   / bh as weight for winter snow removal #4
The back hoe will do a lot of damage quickly if you back into something. Personally, I would use the Kubota weight box and fill it with 500 pounds. I have 650 in mine, much more than recommended, but it has never been a problem for my machine. Last winter, I could climb snow mountains with my tractor and just about set it upright. The weight box also acts as a safety stop if you need. Just drop it on the ground and the tractor stops moving usually. I think that mine was about $250, but that was over a year ago and I might be mistaken on the price.
You gave me an idea, thanks Junk
I have a carryall, put some feet on it, weight in it, and I have a weight box that as you say I can stop the motion of the tractor, should it get funny acting.
As usual, you guys have the best ideas ever.
   / bh as weight for winter snow removal #6
Be careful climbing those snow mountains. The mall near where I grew up lost a hoe that way. He climbed up the nice packed sides, got to the top, and the whole mess went right down into the softer middle.
Havent heard of anyone doing it recently but its a "hold my beer and watch this" kinda thing so its bound to happen again.
   / bh as weight for winter snow removal #7
I will have to look for those pictures, but my mountain wasn't that high...
   / bh as weight for winter snow removal #8
I moved snow with and without the hoe on. There is no question it improves traction. But like plowing with it off . I put a 3PT six foot blade on the back for added weight and use that also .
Dave in NH
   / bh as weight for winter snow removal #9
One thing that the replies aren't mentioning is that having the hoe on for the winter allows a person to get un-stuck relatively easily. This has come in handy for me several times in past winters, especially the time that I accidentally dropped the tractor (Kubota L3000DT) in the ditch sideways. All I had to do was to lift the rear end up with the rams, plant the hoe, retract the rams & use the rotating of the hoe to swing the rear end of the tractor to high ground.
The only down side I have seen was getting the hoe off in the spring. The pins seemed to rust in pretty good over the winter, so lube the heck out of them.
My 2 cents...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
Ford Tractor (A50120)
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
