BH75 Hoses a popin !
   / BH75 Hoses a popin ! #21
What year is your rig ? mine is a 2005
which hoses failed for you ?- same type of failure as I see - a blow out in the middle of the hose somewhere ?
For me the clincher was the stabilizer hose that raises the leg blowing - not exactly the most demanding part IMO.
2007 or 08 cant remember but its paid for woohoo.
yes same type of failure, no reason, no excessive load just blew. 2 on the loader and 2 for the bh. I would have to go look but i know the one "curl" on the fel hose broke with half load of sand loam, the one to cylinder on dipper stick broke while going from dump to back in hole, a lower hose broke for the bh but i cant remember what it went to and a up/down cylinder broke on the fel while driving with my hand off the joy stick.
my thoughts are just cheep hose when it breaks under a no load situation. Agrivating as it is the hose is easy to fix and not that expensive unless its sunday and you end up at tractor supply trying to build something to make it work because they dont have what you need exactly. That place agrivates the heck out of me, the excitment of the new store was quickly lost when i went there and needed a basic tractor part.
MARATHON 76KW GENERATOR (A58216)
MARATHON 76KW...
CFG Industry MX15RX Mini Excavator (A57149)
CFG Industry...
378721 (A54865)
378721 (A54865)
METAL & WOOD STACKING RANK W/ CONTENTS (A58374)
METAL & WOOD...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
