BH7500 woods
/ BH7500 woods #1
alford57
west fork, ar
kubota
I am having trouble with my backhoe. It is a p.t.o. driven woods BH7500. The out riggers and the boom bleed off. They fall in less than a minute. Does anybody have any info on this. Thanks
/ BH7500 woods #3
This may not help . . . but it's a start!
Make sure that the hydraulic fluid level is not low. Carefully check the suction line to the PTO pump to insure there are no leaks. Then move all the cylinders through their full range several times to bleed the system of any entrained air.
bumper
/ BH7500 woods
I will give it a try. just got it a few months ago.
Had to change the main hose.Thanks
/ BH7500 woods
Thanks, I also have a international. Its a 2400a, but it needs a head gasket.
/ BH7500 woods #7
Depending on the number of hours/years on the cylinders, it could be that the packing/"O" rings are worn and leaking by.
/ BH7500 woods #8
Welcome to TBN..
Try cycling all the cylinders as mentioned to bleed the air out.
Messicks.com or woodsequipment.com should have a downloadable parts and / or operator manual.
/ BH7500 woods
Thanks, I am thinking this may be the problem. This backhoe set for a long time before I got it. Worked fine at first. but is beginning to show its age.
Bobcat T650 Compact Track Loader (A64047)
Bobcat T650...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
Unverferth 235 Seed Tender Wagon (A64047)
Unverferth 235...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2017 Ram 5500 Bucket Truck (A63118)
2017 Ram 5500...
Fair Oaks 10'  Multigrader Blade (A64047)
Fair Oaks 10'...
