Big Stump, Little Tractor
   / Big Stump, Little Tractor #1
Mike_V
Boca Raton, FL
BX24
A bischofia tree died suddenly. It was probably hit by lightening.
Could I and my little BX24 remove it and get the stump out? After struggling with a much smaller tree a few years ago, I knew I would need a better way than just digging and pulling with the backhoe. Indeed, I found a way that worked and with the help of a chain saw and garden hose, here's the result.
Here's how I did it.
First, I only cut off the top branches. I left the bottom 15 ft. of trunk. Then, I found a spot about 5 ft. away from the trunk where I could start digging a hole with the backhoe. It took a few tries before I found a break in the roots where I could at least get the bucket in between some of them. I dug the hole about 3 ft. deep. Then I washed the dirt (sand, mostly) off the roots into the hole so I could cut out about a 3 ft. section of the roots with a chain saw. I proceeded that way around the tree, until all of roots were cut.
Then I pulled the tree over with a chain. Once the tree was over, I filled part of the hole to make a ramp to roll the stump out. The picture shows how the chain was run over top of the roots in order to roll it out. Now that it is out of the hole, I can roll it with the FEL as long as I leave the trunk attached.
This is probably a standard technique for people who do this a lot, but I couldn't think of any other way to get the stump out myself.
I'm not sure what to do now, but I've seen where stumps like this can be made into tables.
   / Big Stump, Little Tractor #3
Heck of a job. I'm impressed!!!!!
   / Big Stump, Little Tractor #5
Just like the little engine.."I think I can..I think I can" and he did..thumbs up on nice well done job. :)
   / Big Stump, Little Tractor #6
That brought a big smile to my face. nice job OP. Reminded me of the popular stump I just dug out last spring for a neighbor. It was bigger then the FEL, Pretty heavy too when I was lifting it. I had to extend the boom out of the BH for balance and was able to move it slowly to its final resting place.
Diggin out stumps can be fun when you work carefully.;)
   / Big Stump, Little Tractor #7
My neighbor has a stump similar to that and it looks great in his yard. What the guy did was to dig a hole in the corner of his yard and plant it upside down -root side up- so it looks like a mushroom. After about a year of weather the dirt is all gone and the root system has the look of driftwood and it make a unique - not to mention cheap - lawn decoration.
   / Big Stump, Little Tractor #8
I've done quit a few of these, mostly with my truck, either the 12K winch or pulled out with the trailer hitch....but if you fill the hole with water for a day before and keep it wet, often there is very little cutting to do...
Nice Job...
   / Big Stump, Little Tractor #9
You can't do that...your tractor is not a "B" tractor!!:D:D
Deano
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
2018 VOLVO EC350EL EXCAVATOR (A60429)
2018 VOLVO EC350EL...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
