Big Tex---Beware!
   / Big Tex---Beware! #11
with the ratings on some of the pt, be careful, as it might corrode the metal flange it rests upon!
   / Big Tex---Beware! #12
When i bought my trailer, locally made, i wrote the dealer/manufacturer with detailed specs that called out, among other things: final agreed on price; soldered and heat shrinked (shrank?) connections; looms; empty weight; type of hitch; hitch height for level towing with my specific vehicle; location and type of ramps and stowage; ramp length for correct approach angles; color; diamond plate instead of wood; rear fold down feet for loading heavy gear; spare tire; etc.
That accomplished two things. First, it gave him the opporunity to verify the price he quoted for what I expected to receive and the opportunity to change it before he accepted the bid. Second, it gave me the opporunity to inspect the trailer upon delivery against my written specifications.
When I arrived to pick up the "first" one, it was not near spec. Wiring was taped up and butt connectors, safety chains were not correct for weight, pin striping was horrible, and worst, the ramps were not set up so they could be hooked close enough together to load all my different size equipment. Oh, and it did not come in anywhere near weight, but was about 800 lbs over. It WAS a "solidly built" trailer. He finally admitted about all he could do was shave off a couple of hundred pounds and could not meet the weight spec. It was winter and it had surface rust all over it and had not even been driven off the lot yet.
Well, he was gracious about it after I wrote a letter referencing my initial specifications. He took it back, sold it to someone else, and made me another one. Second one, while not perfect, was much better. I am more or less satisfied with it and it tows well.
Moral: when ever buying something expensive, get you wishes in writing. This includes autos, tractors, trailers, computers, etc. Anything that is not spelled out or that might bug you later, you should make sure you document. No one else will do it for you. Had I not done that, I would have been stuck with a $2200 trailer that I couldn't even use for most of what I purchased it for.
amp
   / Big Tex---Beware! #13
Apitong is the best wood to use if you can suffer the price. For my new trailer the deck alone would have been $1,000. Never will it need replaced though.
I have no idea where to buy PT southern pine rough sawn in 2" thick nominal size. I figure trailer mfg have it made special.
   / Big Tex---Beware! #14
You are absolutely correct. I had not even considered that though I should have since I have been using hardware that is supposed to be compatible with PT on my barn.
There is an article in the latest issue of Fine Homebuilding magazine that shows a carpenter covering PT headers with peel and stick flashing prior to nailing joist hangers on.
Makes oak sound pretty good.
   / Big Tex---Beware! #15
I've had a Big Tex CH70 for a few years now. I don't use it all that often but so far the wiriing has held out. I too am an electrician and will likely rewire it with TEC cable some day if needed. The planking isn't the best quality for sure as there is a few on there that are twisted and weak but so far has done the job. Thought about planking another layer over top of them in the other direction but that would add a fair bit of weight. If I have to replace the wood some day I would likely use pressure teated 2X6 which is spruce or pine around here. The paint has held out very well compared to SWS or Darco trailers I see around here.
Would I buy another Big Tex. Yep, I think so.
   / Big Tex---Beware! #16
for you guys thinking about using pine/spruce/fir etc. those are soft woods. treating them doesn't do anything to the cellular structure, just makes them unappetizing to insects and provides some protection against moisture penetration.
i would suggest hard wood planks like oak/hickory/etc. should be available rough cut form a local sawmill. soft woods gouge very easily but may be used depending on cross member spacing and load distribution.
if you can easily dent it or scratch it with your fingernail, it's softwood.
i wouldn't rest the back hoe of a full size tractor on a piece of soft wood without expecting a serious divot. get it vibrating while you go down the road and you'll have a hole or crack in no time. forget about any kind of track or steel wheel vehicle.
i have two trailers right now that are starting to look a bit sketchy. my dad decked them with treated yellow pine. they don't often get heavy loads, but just scraping out the mulch or manure with a sharp shovel scratches up that soft pine. they also didn't weather that well.
amp
   / Big Tex---Beware! #17
I have similar observations, and will offer some opinions.
Yes.. the pin boards were/probably are untreadted.. My original ones ( 2000 ) lasted about 1 year and then rotted out onthe ends.. I repalced them with PT lumber and then painted them with black asphalt fence paint.. I've had those same boards on since 2001, and they are still good.
Yes.. big tex drilled holes in some areas and ran the wires thru with no grommets. Also check out the brake axle.. Mine quit, and I found dexter axles ( good ).. but the wires pass thru the axles with -NO- grommets.
I went back and used a couple feet of rubber gas line and made grommets anywhere wire passed thru a metal piece. And yes.. every but connector had a bad connection.. I soldered on new wires and used either grease filled crimp caps.. or used rtv to seal caps or splices. I did this about 2 ys ago and have not had a wire problem since.
On the plus side.. the actual frame and suspension on the trailer looks real solid.
soundguy
Propjob said:
Well; I picked up my new Big Tex 70CH Trailer this week after much reseach and information retrieval on the forums. Features that I liked are the slide out removable ramps which can also be used to load smaller tractors and ATV痴 from the side of the trailer. The surround rail in the front (which is not available on the 60CH) is a little extra protection and place to tie down smaller items such as tool boxes, tarps,ect. Stake down pockets are at very convenient locations on the trailer and leave no concern for tie down points for the large web straps that were purchased. The four wheels have electric brakes, and I needed to purchase a brake controller for my Tacoma, Now here is the downside! The wiring of this trailer, (also stated by other posters) is poor. I have spent more than thirty years wiring Public Safety vehicles and was astounded at the way these things are wired. To start, the wires are spliced with scotch locks and butt connectors. No silicon or sealant used. No loom is used on the wiring as it loops around the trailer and at points against the metal frame, which, will result in chafing. Although metal loops are welded on the frame utilizing plastic grommets, the wires on one side were looped over one of these, again a place of chafing concern. I have taken the time to seal the connectors with tape and also will use mastic. I have also put split loom on most of the wiring assuring the areas are protected from the elements and chafing. While under the trailer I noticed that the pine boards used were not of the best quality wood, definitely less than select with gouges in them and I am not sure if they are treated at all. These will get a coat of sealer or deck paint before it goes to far. The dealer, Joe, in Tilton NH was great, taking the time to show me the proper maintenance of the rig and going over the manual.
While on the outside, these trailers are well made, they are problems just waiting to manifest if not taken care of when bought. I knew what I was buying for the price and am able to ward off the seen problems. I caution all on their quest for a new trailer. Get under it! It is a shame that what is touted as one of the biggest manufacturers of trailers, has poor quality in such a critical area, as the electrical. Jim
   / Big Tex---Beware! #18
Although a poor practice all the wiring methods sound about normal for most trailer manufacturers.
The only trailer I have that was done right is a Featherlite all aluminum, including the floor, enclosed trailer. All the wiring is automotive grade with plug in sealed connectors. Of course a Featherlite is about 50% more than the other brands:eek:
   / Big Tex---Beware!
Well, as one of you said we get what we paid for! Fortunately we have the technology and skills to correct it. You know, all it would take is one of the trailer manufacturers to make some of these changes, charge a fair amount and showcase that to the customer. JIM
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
