mrutkaus
Platinum Member
- Joined
- Feb 1, 2004
- Messages
- 990
- Location
- 15 mi. N. of Winchester VA
- Tractor
- Kioti CK30HST, Kubota BX-1500,
Animal fat was the first oil, for lamps and later for greasing wagons.
Mike
Mike
California said:This ought to be interesting! The professional petroleum engineer and the professional waste water treatment engineer discuss pouring oil on the ground.
I know both of you are polite and reasonable. I would like to learn more about this topic (I have spots where Dad dumped oil that still won't grow anything) so it will be interesting to see where this topic goes if you guys are willing to discuss this further.
Ralph, what happens if that oil gets into the groundwater before it is completely broken down?
AlanB said:I will throw in a couple of thoughts.
While throwing words around like "hazardous Waste" sounds good on a website such as this, "used Oil" is very seldom considered "Hazardous Waste" There are certainly times and instances when it falls into that category, but they are by far the minority.
Anyway, California, as to what you are referring too, I think you are referencing Peat. There are several Peat products used for Bioremediation.
The short version is they dig, sift, sort the peat, then dry it. At that point peat works very well as an oil / hydrocarbon absorbent. It will also not absorb water which is a very handy feature when talking about spill remediation.
The peat will take the hydrocarbon into the cell structure and then not release it in the normal battery of tests used by the EPA to determine disposal or charachteristics of a waste.
Several areas are doing in-situ remediation of spills, seeps, old ground contamanition etc. with Peat.
Here is one of the manufacturers that we work well with.
Environmentally Friendly Peat Moss Absorbents
There are a bunch of others out there as well.
Something else you may find interesting is a process called land farming.
Short version again is you take your POL (Petroleum, Oil and Lubricants) contaminated soil, spread it out over a controlled area, water it and add microbes, often in the form of turkey or chicken poo, capture the leachate and then re-use it as top water, turn your mix exposing it too the air, while keeping some of it "cooking" if you will. The longer carbon chains will break down and the shorter carbon chains will go out into the air, often times this soil is then sold (after meeting standards) as road fill, landfill topcap etc.
We looked at doing it in house at one point and it was not economiclly feasable for us.
Our POL contaminated soil currently goes to a Landfarm up in FWJ's neck of the woods
Not really positive if that is what you were referencing, but it sounded close.
Soundguy said:Sounds like your mind is made up.. so i won't waste time discussing the point.. except that to say that most of the people who classify waste oil as hazardous waste are: the government..
DOT lists waste oil as a hazardous waste. strikingly enough .. so does the EPA..
The epa has 4 big list.. F, K, P, and U.. and anything not on those lists that meets D001, D002, D003, D004-D043 specs also qualifies. ( 1, 3 and 4 especially )
Soundguy
