Black Smoke followed by sudden death?
   / Black Smoke followed by sudden death? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
Yesterday I was moving a bunch of dirt with my Iseki TX1500 (Bolens 172) and after about 3 hours of constant running, It started to sputter like it was running out of fuel.
I shut it down quickly to hopefully prevent having to bleed lines and all that. When I checked the fuel tank it was still 2/3 full.
I let it sit for a bit and then went to start it. It was really hard to start. It sputtered and coughed and spewed a lot of black smoke. After a while of running the starter it finally sputtered to life coughing black smoke the whole while. After about 10 seconds of running it died again.
I repeated this scenario about 3 or 4 times and then gave up. It seemed like the longer it sat in between starts, the longer it would run before it died. We loaded it on the trailer with a come-a-long, and there it sits.
I'm thinking fuel pump, but I'd like input from the rest of you.
   / Black Smoke followed by sudden death? #2
I'll vote for fuel filter..
   / Black Smoke followed by sudden death? #3
Check the filters. Fuel and air. Make sure they are clean. Check that the oil is still oil and not a mix of oil and fuel. A leaking fuel pump, injector, or line may fill the crank case and give similar symptoms.
Good luck
jb
   / Black Smoke followed by sudden death? #4
The description sounds just like when I had an injector nozzle fail on a 3000 Ford earlier this year. Black smoke is usually a sign of too much fuel rather than not enough/none.
   / Black Smoke followed by sudden death? #5
Not fuel filter, The black smoke is evidence it's getting fuel. It's also evidence that it might not be getting enough air.
If it is not the air filter or something else blocking the admission of air into the engine, you have non-trivial problems, such as a bad injector, injection pump, or pump timing.
   / Black Smoke followed by sudden death? #6
Check the fuel filter(s) and air filter.
They are the most likely culprits.
Also chceck for sludge/moisture in bottom of fuel tank.
Was it cold out? I'd also consider running some Dgel/Injector Cleaner through the fuel system.
   / Black Smoke followed by sudden death? #7
I'm also on the air filter bandwagon. Black smoke is proof of fuel.. lots of it.
( could also be injector pump overfuel problem.. )
soundguy
Well, You've all answered the first question I had for myself... Do I try to tackle this on my own or take it in somewhere?Based on the varied theories from the gallery, I think I'll take it in to someone who has a few more diagnostic tools than I do.
I just replaced the fuel filter before fall. I drained the tank at the same time I replaced the fuel filter. I haven't even gone through a full tank of fuel. It was cold that day...about 25 degrees, but I filled up about 3/4 of my tank that morning with this season's blend, and I added power service when I filled up.
It makes sense what everyone is saying that the black smoke means it's getting at least enough fuel. I did check the air filter at the time I was having the problem, but it checked out okay too. It's a fairly new filter, and I didn't see much clogging. I knocked it on my boot and dust came off of it, but not in a thick cloud like I've seen in clogged filters.
   / Black Smoke followed by sudden death? #9
Make sure the entire intake tract (both downstream and upstream of the filter) is clear, not just the filter element. Something may have come loose and could be blocking some part of the air intake system.
Also, it is a good idea to replace that element now that you've taken it out. The seals on air filter elements develop something of a memory and are not likely to seal as well when reinstalled.
   / Black Smoke followed by sudden death? #10
Replacing fuel filter before fall does not mean you now have a plugged or water laten filter; Check it again. It won't hurt and it may contain debris. What does the crankcase oil look and smell like? Is it contaninated with fuel?
2015 Ford F-650 22ft Flatbed Truck (A44571)
2015 Ford F-650...
2001 Ford Excursion SUV (A44572)
2001 Ford...
2007 Chrysler Aspen (MPV), VIN # 1A8HW582X7F516547 (A44391)
2007 Chrysler...
295 - 5952 CAT Bucket 24in (A44391)
295 - 5952 CAT...
2011 Ford F-250 Super Duty Rawson Koenig Service Truck (A45336)
2011 Ford F-250...
Amida Generator/Light Tower (A44391)
Amida...
