Blackberries! Ah!
   / Blackberries! Ah! #21
Of course this is just a guess, but the burn ban may be a result of colder temperatures and a lot of dry grass/brush/leaves during the coldest months.
   / Blackberries! Ah! #22
Blackberries have developed the secret to eternal life. Mow them and they sprout. Till or otherwise excavate and broken off roots and rhizomes sprout new plants.
The only thing that works well is chemical warfare. My local guru says Crossbow in the spring and Roundup in the fall. I haven't tried much Crossbow, but Roundup in the fall before a hard freeze does work. But since physiological process have slowed down in the fall you won't see results very quickly. I sprayed some in late August and suddenly in mid November they were dead. If they are drought stressed in the fall, spraying then won't work so well.
A friend sprayed a lot with 2,4-D in late summer-early fall and it sure worked for him, even tho it isn't supposed to work on blackberries. The canes are dead,dead,dead. Don't know about the roots. And I don't remember the formulation.
When I was doing a little forestry consulting I had a client who had 12 ft. tall noble firs that had been planted for Christmas trees and then abandoned. Blackberries were all entwined up to the upper foot or so of the trees. My logger had a trackhoe on site, so he went in and pulled up the berries, opening up the area so the 70 year old lady could go in and spray. she did that and a couple years later the berries were 99% gone and the trees were doing well.
   / Blackberries! Ah! #23
Pitty they weren't the RIM kind, or you could've made a fortune!
   / Blackberries! Ah! #24
I worked in the PNW for a while, you guys have serious blackberry canes. Far worse than here in the NE. Proper herbicides can work well and are safe if used properly. Older farmers will throw a few hay bales into a patch and let the cattle loose in winter. They will knock blackberries back where you can get them under control.
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
Brent 420 Grain Cart (A56438)
Brent 420 Grain...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
(2) UNUSED 31" X 10 MM EXCAVATOR TRACKS (A60432)
(2) UNUSED 31" X...
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
2004 Ford F-150 Ext. Cab Pickup Truck (A59230)
2004 Ford F-150...
