Block heater needed for BX22?
   / Block heater needed for BX22? #11
Years ago, I had a ford pickup that in the winter, had to start, high idle, and warm up until the choke turned off before you could drive. If you tried early, the choke would stick and you were out under the hood, manually releasing the choke.
This was in the 70's energy crisis, with the unheard of high prices, so I figured the cost to install a block heater and run it on that truck more than was offset in saving with less gas spent.
It also had the side benefit that I could switch on the ACC switch, and the DEF fan to high. Five minutes later, the ice was off, the windows clean.
Just unplug and take off. I loved it.
Ron
   / Block heater needed for BX22? #12
Honestly,
My tractors are my babies... /forums/images/graemlins/smile.gif
They certainly don't need a block heater to start.
The block heater may or may not add to their longivety.
The Block heater makes me feel good... /forums/images/graemlins/blush.gif
I have never heard anyone say a block heater is BAD for an engine.
I have concluded it can't hurt, and it might help.
Since it also makes me feel good...well, it's a win-win proposition! /forums/images/graemlins/cool.gif
I have block heaters in both of my tractors and use them...because it makes me feel good
Your milage may vary... /forums/images/graemlins/grin.gif
edit: Well...I have not had the bx2200 thru a winter yet...but you can bet that block heater will used! /forums/images/graemlins/smile.gif
   / Block heater needed for BX22? #13
<font color="red"> As to your heighbor .... does he keep his machines for a long time , or trade them in regularly ? I'd be willing to bet he doesn't keep them as long as those of us that use a machine for "home use </font>
He keeps everything; has never sold or disposed of any equipment since I've lived here; keeps adding more tho!
THANKS FOR ALL INFORMATION /forums/images/graemlins/smile.gif
   / Block heater needed for BX22? #15
It may not be a factor for your BX22 but I have a B6100 gear drive and the hydraulic tank for the FEL is, of course separate from the engine. I don't have a block heater and my tractor starts fine in the coldest winter temps but the FEL is VERY slow because the hydraulic oil gets very thick.
For an HST tractor, will an engine block heater also heat the hydraulic oil?
   / Block heater needed for BX22? #16
Snowman .
You make a good point ! If I had as much equipment as your neighbor I wouldn't plug in either . The electric bill would be staggering /forums/images/graemlins/smile.gif All the best , JOHN
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2013 PCI MANUFACTURING 130BBL VACUUM TRAILER (A53843)
2013 PCI...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
