Bobcat 763 Help
   / Bobcat 763 Help #61
:thumbsup:
Don't over tighten the jam nut, or it will damage the O ring again. :eek:
   / Bobcat 763 Help
Nice job making that socket. Did you cut the hex with a torch? I've done that a few times. Glad you got it out.
Thanks for the compliment. I drilled along the perimeter of the hex using a 1/8" bit, then used a chisel to punch out the center and finished up by using an end mill in the milling machine. It worked well.
:thumbsup:
Thanks for the tip. I have it installed and it doesn't appear to be leaking. I'm guessing it is torqued to about 20 to 25 ft/lbs. Just a guess though. Sure hope I never have to do this again but if I do it should not be anywhere near as hard to get off.
   / Bobcat 763 Help #63
and you now have the tools.. :) good job!!
3Pt Aerway (A59814)
3Pt Aerway (A59814)
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2010 Deere 318D (A60462)
2010 Deere 318D...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
